05-06-2014, 11:41 | #107 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
It not support, because I not seen such phones at all. When I can check at least one - it will. If you want help us improve it, and can sell this sample - will be great. Format/Flash will not work, if CM not determine data correct. It save user from problems. | |
05-06-2014, 13:47 | #108 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | 6530a not format lianke p200 set is ok only touch screen calibration problemStart at : [5/6/2014 / 3:49:19 PM] Operation : Format File System Settings : SmartFormat is On Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 Flash DIE : 002C 00CB 0017 0000 Flash VEN : Micron , N25W64 Flash CAP : 00800000 Verify data... Can take some time Error while prepare! Format error, something went wrong Reconnect Power/Cable! |
05-06-2014, 14:50 | #109 (permalink) | |
05-06-2014, 15:13 | #110 (permalink) |
Crazy Poster Join Date: Jan 2012 Location: Dominican Republic
Member: 1711990 Status: Offline Sonork: jmgcommgroup Thanks Meter: 1 | Bmobile K106 I have a Bmobile K106 with Spread CPU that I want to unlock, I have infinity, looking to test. This soft have unlock option to test??? |
05-06-2014, 17:42 | #114 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0060 0018 0000 Flash VEN : Winbond , W25Q128 Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Format error, something went wrong :( Reconnect Power/Cable! |
05-07-2014, 13:53 | #118 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Problem With Dual-Flash Ic Problem With Dual-Flash Ic Model = Pel-C68 Problem = Restart Cpu = 6531 16mb Format Not Working Code: Card found: S/N B3F6:0126 Chinese Miracle II [SPD module] v 0.04 Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 002C 00CB 0018 0000 Flash VEN : Micron , N25W128 Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Format error, something went wrong :( Reconnect Power/Cable! Here Is File Read Info Code: Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 002C 00CB 0018 0000 Flash VEN : Micron , N25W128 Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B.W13.11_Release ExtInfo : Compile time is invaild! Project : SC6531_BAR HWInfo : SC6531_BAR Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B.W13.11_Release_Compile time is invaild!_.bin Done! Elapsed: 00:01:26 Reconnect Power/Cable! SPD6531_01000000_MOCOR_12B.W13.11_Release_Compile time is invaild!_ |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
05-07-2014, 14:11 | #119 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Another Problem With Spice M5916 Another Problem With Spice M5916 Reading Ok Writing Ok But Format Not Done Model = Spice M5916 Problem = Restart Cpu = 6531 16mb Code: Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Format error, something went wrong :( Code: Reconnect Power/Cable! FastCheck : SPD65xx Load file... ExtInfo : SPICE_M-5916_IND_V11.0 Project : SC6531_PDA HWInfo : SC6531_PDA Load Ok Operation : Flash ======= Flash Files set for flashing : [ MCU ] : Spice M-5916 6531A_MX25U12835E 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : Spice M-5916 6531A_MX25U12835E Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:04:11 Reconnect Power/Cable! |
