04-04-2007, 15:21 | #16 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: Belarus
Member: 170408 Status: Offline Thanks Meter: 120 | Quote:
? Tx ? Rx | |
04-04-2007, 17:28 | #17 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | Quote:
i find the rx & tx and the phone is ok by infinity box thx for all B.R. hassan | |
05-26-2007, 19:14 | #22 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 235616 Status: Offline Thanks Meter: 67 | hello sir i need pin out for chines nokia n95 rh37 its pin look 2x5pin 10=gnd 1 = +voltage ------------- 2nd cect m881 pin out 2x7pin 6 =gnd 4 = +voltage pls i need full pin out for making new cables |
05-26-2007, 19:53 | #23 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! compare pinouts with avalible on support. maybe you will find same configuration gnd, and charging voltage. if not you have to search all pins one by one |
05-27-2007, 20:15 | #27 (permalink) | |
Freak Poster Join Date: Dec 2000 Location: Burkina Faso , Bobo Dioulasso Age: 53
Member: 2920 Status: Offline Thanks Meter: 21 | Quote:
I've chinese nokia N88 with following pins Keyboad up ............................................ 1 24 -7 & 8 charging -10 USB -13 USB -14 & 17 Gnd -23 Vbat1 -24 Vbat2 -I just know that pin 12,18 and 21 voltage raise on power on when pin 19 drop. -I measured Gnd to Pins and find that pins 2,5,6 & 22 seem to have low resistance I tried all combinaison from that but no chance. | |
05-27-2007, 21:16 | #28 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! easyer and faster is to solder all connector pins to IC socet and try all possible combination in less than 30min. here is how i do this: http://forum.gsmhosting.com/vbb/show...8&postcount=18 also, need to remmber that in some models Tx, rx wires is not connected to system connector, but to test points on PCB (which is sometimes even marked) |
N73, N72 chinese miracle Cable mod | kaino147 | Infinity-Box | 8 | 06-15-2008 11:33 |
<<<__N73 cable to use with the 29pcs chinese miracle cable?__>>> | keaelite | Infinity-Box | 1 | 11-04-2007 11:25 |
Chinese Miracle cable Pinout problems | kaino147 | Infinity-Box | 12 | 09-04-2007 15:51 |
Chinese Miracle Cables For Infinity,uni Box,ust-pro2,nspro,vygis,redbox,furious Gold | paklink | Main Sales Section | 0 | 06-20-2007 18:39 |
Chinese Miracle cable set needed ASAP | armkbdotcom | Wanted Products | 1 | 01-19-2007 02:55 |
