chinese miracle CECT p168 ? I have this phone and small softwer problem.. I want to flash this phone but I dont know which files must write to upgrade softwer... On the back side phone behind batery write these: CECT P168 Imei:35140513072xxxx Log from infinity box: Read general information: Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E688_Y5BT699.01.1_26 Software date: 2005.04.12 Barcode: GTL06060728004988 imei: 35140513072xxxx Finished, time used: 23 sec Power off phone now ! Now Read full flash: COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.BBA61E12.[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN_066314A3].rpl New firmware detected: E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: BBA61E12 protocol ver: 04 ver. sw1: E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN ver. sw2: E688_Y5BT699.01.1 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [flash[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN]]... warning: wrong data size at 0x00F8F800, retry... read error recovered file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN]_20071112-200924.B0M.bin file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _BBA61E12_E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y 5BT699_01_1.BIN_066314A3_20071112-200950.B0X.bin Finished, time used: 895 sec Remove/Install battery now ! I am confused now?? on suport can not find any flash for this model???.... can I write this flash: CM_Cect-P168_BR26_05C_PCB01_GPRS_MT6226_S01[1].BR26_22_15_16m_En_Fr_Es_Pt_Ar.B0M or this: CM_Cect-P168_BR26_05C_PCB01_GPRS_MT6226_S01[1].BR26_23_11_16m_En_Cn_Cn_Es_Fr_Ar_Pt.B0M or must wait for new flash files for this model.....If write this flash file probably kill phone or......? Please Help..... THX. |
2. you can use for flashing files with firmware version similar to E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1 Find files by firmware version, not by phone model name. |
OK I understand that.. no problem for that..I send you tomorow all backup files.... But I cant find any firmware like E550_Y5BT699_E550_GPRS_MT6226_xxxxx or something like that....or I cant see...any firmware E550_Y5BT699..... |
hello! have you tried Format FFS? maybe this will help, so no need to flash |
I hope you understand me... Try today Format FFS and post result..... |
hello! did you try both formating FFS? safe and complete? if both ways do not help- you can try to flash. you must use for flashing files with firmware version similar to E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1 Find files by firmware version, not by phone model name. Do not forget to save flash backup for emergency case |
