Old 11-12-2007, 20:23   #1 (permalink)
Member: 83374
Thanks Meter: 6
chinese miracle CECT p168 ?
I have this phone and small softwer problem..
I want to flash this phone but I dont know which files must write to upgrade softwer...
On the back side phone behind batery write these: CECT P168 Imei:35140513072xxxx
Log from infinity box:
Read general information:
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E688_Y5BT699.01.1_26
Software date: 2005.04.12
Barcode: GTL06060728004988
imei: 35140513072xxxx
Finished, time used: 23 sec
Power off phone now !
Now Read full flash:
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.BBA61E12.[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN_066314A3].rpl
New firmware detected: E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
device-id: BBA61E12
protocol ver: 04
ver. sw1: E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN
ver. sw2: E688_Y5BT699.01.1
ffs offset/size: 00800000/001FF000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [flash[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN]]...
warning: wrong data size at 0x00F8F800, retry...
read error recovered
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1.BIN]_20071112-200924.B0M.bin
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _BBA61E12_E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y 5BT699_01_1.BIN_066314A3_20071112-200950.B0X.bin
Finished, time used: 895 sec
Remove/Install battery now !
I am confused now?? on suport can not find any flash for this model???....
can I write this flash:
CM_Cect-P168_BR26_05C_PCB01_GPRS_MT6226_S01[1].BR26_22_15_16m_En_Fr_Es_Pt_Ar.B0M
or this:
CM_Cect-P168_BR26_05C_PCB01_GPRS_MT6226_S01[1].BR26_23_11_16m_En_Cn_Cn_Es_Fr_Ar_Pt.B0M
or must wait for new flash files for this model.....If write this flash file probably kill phone or......?
Please Help.....
THX.
Old 11-12-2007, 21:31   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
or this:
Please Help.....
THX.
1. pls, read yellow text and send backup_system_log_BBA61E12_E550_Y5BT699_E550_GPRS_ MT6226_S01.E688_Y5BT699_01_1.BIN_066314A3_20071112-200950.B0X.bin file to [email protected]
2. you can use for flashing files with firmware version similar to E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1
Find files by firmware version, not by phone model name.
Old 11-12-2007, 22:19   #3 (permalink)
Member: 83374
Thanks Meter: 6
OK I understand that.. no problem for that..I send you tomorow all backup files....
But I cant find any firmware like E550_Y5BT699_E550_GPRS_MT6226_xxxxx or something like that....or I cant see...any firmware E550_Y5BT699.....
Old 11-12-2007, 23:49   #4 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
have you tried Format FFS? maybe this will help, so no need to flash
Old 11-13-2007, 07:52   #5 (permalink)
Member: 83374
Thanks Meter: 6
hello!
No Iam not...My problem is when I try to select manual network selection....No way...Select manual selection..find network...select manualy network...after that when I back in menu....softwer automaticly back to automatic selection.....and that is a problem...always go in roaming....
I hope you understand me...
Try today Format FFS and post result.....
Old 11-15-2007, 15:18   #6 (permalink)
Member: 83374
Thanks Meter: 6
hello!
today tried format FFS---everything is OK but same problem with network selection...need new flash version I think only new flash help for my problem..
Old 11-15-2007, 20:37   #7 (permalink)
Member: 148515
hello!
did you try both formating FFS? safe and complete?
if both ways do not help- you can try to flash.
you must use for flashing files with firmware version similar to E550_Y5BT699_E550_GPRS_MT6226_S01.E688_Y5BT699_01_ 1
Do not forget to save flash backup for emergency case
SCIPHONE I68/I68+ CECT p168/P168+ & I9 Codes dredyns Chinese Models & Cloned Phones 53 03-24-2011 13:36
chinese miracle, MPEG4, ztc, CECT pinouts here fastlink Jogja Chinese Models & Cloned Phones 1 08-28-2008 16:07
Cect p168... Question for Infiniti team hohlobaks Infinity-Box 19 10-08-2007 16:28
Cect P168? wiserommer Chinese Models & Cloned Phones 0 08-06-2007 22:23
Page generated in 0.33505 seconds with 8 queries
