Old 08-26-2009, 05:47   #1 (permalink)
Member: 587123
Thanks Meter: 7
Chinese Miracle fail!
Hello infinity team!
I have another TV C702 and i could read it with pinfinder very well but when i open Chinese Miracle to know user code, chinese micracle fail and give me this log:
COM19 [VCP0] selected
module v2.90
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4B03:0000
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 78 sec
Remove/Install battery now !
Please infinity team what can you suggest me?
Old 08-26-2009, 07:31   #2 (permalink)
Mallick Manzil's Avatar
Member: 1074634
Sonork: 100.1583894
Thanks Meter: 241
plz try this
change Baudrate-921600 to
115200
Old 08-26-2009, 15:14   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you did not modify your main infinity box- this is the reason.
there is used diode which limit power from 5volt to 4,3v
you must shortcut it and then problems with test mode will gone
you can find this procedure describtion in pinfinder user manual "trubleshooting section"
Old 08-26-2009, 16:32   #4 (permalink)
Member: 587123
Thanks Meter: 7
@InfinityHelp Are you sure is that the problem?? please, because before to lose my guaranty i want to be really sure about it.
Old 08-26-2009, 19:06   #5 (permalink)
Member: 587123
Thanks Meter: 7
hello!
100% Tasted!!! works very well!! thank you so much!! i have unlock TVC702 user code!!
Thank you infinity team!
Chinese Miracle module supported models/features [08-Apr-2007]: inder Infinity-Box 2 02-05-2010 20:24
Chinese Miracle cable set, where?? armkbdotcom Infinity-Box 34 03-02-2008 11:45
motorola F3 chinese miracle? mrfixit Infinity-Box 3 02-19-2007 22:25
Chinese Miracle cable set needed ASAP armkbdotcom Wanted Products 1 01-19-2007 02:55
Chinese miracle telsda mp4?? T6012 SLIPLOCK Infinity-Box 4 01-11-2007 00:17
Page generated in 0.19407 seconds with 9 queries
