Old 02-24-2009, 00:18   #16 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this is 100% because of new flash type.
please be patient few days untill we will release support for this type
Old 02-24-2009, 13:37   #17 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
I have same problem and waiting for update. Forget Spiderman, just read detailed info with CM and look for ours problematic flash number.
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
Old 02-25-2009, 02:03   #18 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Because I use Spiderman for connecting phones, that's a simplier and faster way for me to boot with spiderman tool after pinfinding.
Old 02-28-2009, 21:04   #19 (permalink)
Member: 130995
Thanks Meter: 35,227
@Pecsi.Zoltan
offtopic message was deleted. Here is Infinity-Box support forum but not discussion about anything else.
Old 03-03-2009, 23:21   #20 (permalink)
Member: 130995
Hello,
Please, try to use this software for flashing:
http://www.infinity-box.com/download...acle_v2.78.rar
Waiting for your results.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 03-04-2009, 00:03   #21 (permalink)
Member: 439145
This will be my first thing in the morning tomorrow... I say thank you for the answer! ;-)
Old 03-04-2009, 03:31   #22 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Hi InfinitySupport,
Nice update! It works well on all phones with the new flash chip. I hope so, we'll never meet again with such problem. Thank you for this very important update, your tool is on the top again. Keep it up!
The Following User Says Thank You to bencebacsi For This Useful Post:
Old 03-04-2009, 19:02   #23 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Originally Posted by bencebacsi View Post
Hi InfinitySupport,
Thanks for test report !
Here is official information about ChineseMiracle update: http://forum.gsmhosting.com/vbb/showthread.php?t=693127
The Following User Says Thank You to InfinityN For This Useful Post:
Old 03-04-2009, 20:12   #24 (permalink)
Member: 439145
I say thank you for it, works perfectly the v2.78 and support the new Toshiba devices.
Old 04-07-2009, 21:49   #25 (permalink)
Member: 170455
Thanks Meter: 23
new flash chip
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C403:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:FFBFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: flash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\Firmware_bkp\fly-ying_f222_FF.bin
Finished, time used: 1065 sec
Remove/Install battery now !
unknown flash chip.
br,
Old 04-07-2009, 21:57   #26 (permalink)
Member: 130995
Originally Posted by XTS3000 View Post
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
ffs/eeprom chip: 00
reading: flash...
unknown flash chip.
br,
Hello,
There is nothing with this flash chip.
If your phone can not power-on I suggest you check phone hardware or flash phone with firmware.
Old 04-07-2009, 23:16   #27 (permalink)
Member: 439145
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
ffs/eeprom chip: 00
reading: flash...
unknown flash chip.
br,
I would improve your telephone in this manner with Infinity usage: Format function, if this does not yield a result, then from a telephone with an identical type eeprom area it is necessary to obtain a rescue. I would ask a picture from the telephone, I can help possibly.
Jinpeng C3000 bmster89 Chinese Models & Cloned Phones 1 01-07-2016 06:24
Chinese Miracle cable set, where?? armkbdotcom Infinity-Box 34 03-02-2008 11:45
motorola F3 chinese miracle? mrfixit Infinity-Box 3 02-19-2007 22:25
Chinese Miracle cable set needed ASAP armkbdotcom Wanted Products 1 01-19-2007 02:55
Chinese miracle telsda mp4?? T6012 SLIPLOCK Infinity-Box 4 01-11-2007 00:17
Page generated in 0.30528 seconds with 10 queries
