10-30-2008, 13:32 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Unable to Modify IMEI software version: 1.14 cable type: 2x6 (L12B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM13... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:1 Tx:2 time required: 0 sec Power On ! saved: SimTelep_Mstar ----------------------------------------------------- With all Methods, It Displays as if IMEI is Repaired. But When Actually Checked(*#06#), IMEI is "000000000000000" With Method #3 "imei#3 for Triple SIM CPU", I Got Following Reads. ----------------------------------------------------------- module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #3 for triple sim CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:4903:000D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.L68D_H250_L10 1_T.BIN ver. sw2: L68D_H250_L101_T, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.L68D_H250_L10 1_T.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.L68D_H250_L10 1_T.BIN]_20081030-161734.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: mt62xx[at]gmail.com Patch required data Fail Finished, time used: 194 sec Remove/Install battery now ! Flash Backup Sent to Support. |
10-30-2008, 23:11 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to make following part: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again |
unable to send imei for bb 8830 | ash_karan | Gsmfather The Wholesale Unlocking Database | 2 | 10-29-2009 01:40 |
KU990 unable to repair imei | hiroprotagonist | FuriousGold | 1 | 04-17-2009 12:13 |
Unable to repair IMEI 099999-00-123456-0-09 on T290i? | byteforce | Cruiser Suite | 3 | 02-25-2006 11:51 |
Unable to read IMEI | vikesh | SAGEM JTAG UNLOCKER | 9 | 12-26-2005 07:40 |
Newest Griffin 2.895 unable to rebuild IMEI on DCT3 phones... | byteforce | Griffin | 2 | 05-27-2005 18:12 |
