Old 02-23-2010, 14:16   #1 (permalink)
kfkevin's Avatar
Member: 776382
Thanks Meter: 105
chinese nokia 6303
phone restarts when you try to make a call, have formated it, repaired imei, downloaded flash files from support but still same thing, "RESTARTS WHEN YOU TRY TO MAKE A CALL"
here is original firmware and the different files i tried from support:
GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-2-028_090313__fullflash_20100219-073300.B0M
frm support:
- GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-2-028_090313__NOKIA-6303_16m_En_Ru_Fr_Es_It_De_Ml_Id_Vn_Tr_Farsi_Pt_Ar .B0M
- GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-2-011_090106__NOKIA-6303_16m_En_Ru_Fr_Es_It_De_Ml_Id_Vn_Tr_Farsi_Pt_Ar .B0M
- GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-1-008_081211__6303_16m_En_Ru_Fr_Es_It_De_Ml_Id_Vn_Tr _Farsi_Pt_Ar.B0M
the last two files phone lost display and couldn't call out too.
Old 02-23-2010, 21:05   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
http://www.infinity-box.com/wiki/ind...ot_make_a_call
Old 02-24-2010, 08:37   #3 (permalink)
kfkevin's Avatar
Member: 776382
Thanks Meter: 105
CHECKED OUT THE LINK ABOVE AND ON IT YOU STATE AS BELOW
Power-off with sim card, reboot with sim card, can not make a call
Problem description:
* - phone can not make a call
* - power-off during a call
* - reboot during a call
In most cases it's a result of damaged hardware, but in some cases (f.e. for many Chinese Miracle models) it may be a result of damaged eeprom/ffs area.
How to check what is the problem reason:
* remove sim card from phone
* Power-On phone
* make 112/emergency call
* if phone can not make 112/emergency call (power-off during call, can not make a call, "no network" or other similar message displayed at phone LCD) this means you must repair phone hardware RF part (f.e. replace Power Amplifier a.k.a PA)
* if phone can make 112/emergency call but can not make other calls it may be result of software problem, f.e.:
* - imei is invalid: need to repair imei
* - calibration data is damaged: need to restore factory default values (f.e. via "format ffs" operation)
Thanks but i think its hardware problem b'se even without simcard making emergency calls phone still goes off and on ie instead of connecting it just reboots.
Have given up let me return to customer to try or return it to CHINA.
Old 02-26-2010, 11:14   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this means that it has Power Amlifier hardware problem
Nokia 6303 new hardware exe dulal044 Nokia Hardware & Hardware Repair 0 05-16-2009 13:25
nokia 6303 RM-443 sw 6.20 APAC EURO ?? vmin81 Nokia Base Band 5 ( BB-5 ) 1 05-13-2009 10:47
Nokia 6303 new hardware exe by dulal deb dulal044 Nokia Hardware & Hardware Repair 0 05-02-2009 13:00
Crystal Case for Nokia 6303 Phone (white) IPMART ipmart WebShop 0 04-21-2009 08:00
Page generated in 0.14185 seconds with 9 queries
