03-13-2010, 09:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Chinese Phone Dead after Format I flash both firmware & eeprom backup file, but phone still same.... Solution please... COM4 [VCP0] selected module v3.09 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6903:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.09, database date: 19.02.2010): V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4.BIN project-id: V600CA_XZY_ADI_LANG_C_V3.3.4, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E40000 Detected ffs/eeprom address is non-standard: 00E40000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E40000 detecting ffs/eeprom size... ffs/eeprom size: 001C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E40000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\V600CA_XZY_ADI_LA NG_C_PCB01_GPRS_MT6225_S00.V600CA_XZY_ADI_LANG_C_V 3_3_4__ffs_20100310-161958.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 2 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to thushdt For This Useful Post: |
03-13-2010, 11:56 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to flash with this file: flashfiles/ChineseMiracle/_MT6225/V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_0_16m_En_Fr_Es_It_Pt.B0M.bin |
chaina phone dead after format by using infinity Box | MANfaith | Chinese Models & Cloned Phones | 9 | 09-06-2009 08:38 |
bluetooth china phone dead after formating | Gordak_air | Chinese Models & Cloned Phones | 2 | 11-27-2008 08:19 |
phone dead after format | jbbasha | Infinity-Box | 3 | 10-15-2008 17:01 |
china n92 dual sim phone dead after format | /ARIF/ | Infinity-Box | 10 | 03-26-2008 11:39 |
china n92 dualsim phone dead after format with infinity | /ARIF/ | Chinese Models & Cloned Phones | 1 | 03-22-2008 01:24 |
