03-21-2010, 10:42 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Chinese phone INVALID IMEI yesterday I received a chinese phone dual sim..L700.. IT was off.. With complete format the phone revived but after power on it show IMEI INVALID so cant use any sim I tried all ways...auto baud rate boot select--mode 1.2.3 here is the log;;;; Code: ==== log: [3/19/2010 9:12:41 PM] ==== COM5 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #2 for dual sim/mono CPU new imei: 355265312132137 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E503:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): R206AN_ZH_F15_PCB01_GPRS_MT6225_S00.R206AF_ZH_F15_V14_091109.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: R206AN_ZH_F15_PCB01_GPRS_MT6225_S00.R206AF_ZH_F15_V14_091109.BIN project-id: R206AF_ZH_F15_V14_091109, 00000000 code offset: 00000000 ffs offset/size [01]: 00E40000/001C0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E40000 flash: EC240200000000:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E60000 Detected ffs/eeprom address is non-standard: 00E60000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E60000 detecting ffs/eeprom size... ffs/eeprom size: 001A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E60000-00FFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R206AN_ZH_F15_PCB01_GPRS_MT6225_S00.R206AF_ZH_F15_V14_091109__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R206AN_ZH_F15_PCB01_GPRS_MT6225_S00.R206AF_ZH_F15_V14_091109__ffs_20100319-211725.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 4 min 58 sec Remove/Install battery now ! kindly have some suggestion thanks a lot now I'm reading its ful flash to send it to infinity team...regards azeem781986 |
The Following User Says Thank You to azeem781986 For This Useful Post: |
03-21-2010, 10:44 | #2 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | phone also dont make format ffs as it turns completely on while formatting safe FS so when it says while repairing imei that phone should be pwer on then it dont connect as ALL connectivity of tx and rx +gnd is good and fully working thanks in advance |
03-21-2010, 12:01 | #4 (permalink) | |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Quote:
I did same while connecting with mode I- I remained the phone powered on but didnt connect to soft and the bar exceeded to 100% | |
03-21-2010, 15:36 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, What to do: 1. make full flash backup for emergency cae 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again Did you tried to follow this instruction ? |
03-21-2010, 16:01 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @riders4siam Here is Infinity-Box support forum but not a discussion about anything else. Your offtopic message was deleted. You must think before make posts in wrong forum. Thank you for your kind understanding ! |
03-21-2010, 17:13 | #8 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | here is full flash its new FIRMWARE DETECTED link for infinity support 4shared.com - online file sharing and storage - download bauR206AN_ZH_F15_PCB01_GPRS_MT6225_S00.R206AF_ZH_F 15_V14_091109__fullflash_20100321-075851.B0M and Sir I have again done this procedure: What to do: 1. make full flash backup for emergency cae 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again but same problem IMEI NOT DETECTED so I uploaded to 4shared and hope ASAP infinity team will help me out regards azeem |
03-22-2010, 08:51 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
http://forum.gsmhosting.com/vbb/f425/china-phone-motorola-a7-motorola-a1210-2nd-sim-emergency-955176/ | |
03-23-2010, 05:54 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! right now i see most easiest way for you is to make IMEI change via bluetooth. IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum |
03-23-2010, 09:55 | #12 (permalink) | |
Thanks very much Infinity Help My Issue Solved through Bluetooth Port here are screen shots Thanks very very much Infinity One of the best device Specially For Chinese and cloned phones | |
IMEI change chinese phone | reaz.com | Infinity-Box | 13 | 11-30-2009 20:22 |
<<<Bomb Again chinese phone 3 imei repair>>> | υИқИΘШИ® | Chinese Models & Cloned Phones | 3 | 01-17-2009 15:27 |
New solution for unlock NEC 3G phones - but IMEI changes - and only chinese language! | laxxe | NEC | 33 | 06-18-2006 23:31 |
