Old 09-26-2007, 12:01   #1 (permalink)
Pragyan_Gehlot's Avatar
Member: 503334
Sonork: 100.1590885
Thanks Meter: 173
Red face Chinese Ztc Zt303 100% Procces Then Phone Off
I HAVE ZTC ZT303.
PHONE 100% PROCCES THEN OFF.
I DONE FLASHING & FFS FORMAT.
BUT PHONE NOT NORMAL ON
PLEASE HELP ME:confuse d::confuse d:
Old 09-26-2007, 12:10   #2 (permalink)
Member: 264597
Thanks Meter: 2
you must read full flash from other hand that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware
Old 09-26-2007, 12:10   #3 (permalink)
Member: 264597
Thanks Meter: 2
you must read full flash from other hand (ZT303) that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware
Old 09-26-2007, 12:49   #4 (permalink)
Member: 503334
Sonork: 100.1590885
Thanks Meter: 173
COM3 [VCP0] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: write NAND flash
"format ffs" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
protocol ver: 04
ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B015.BIN
ver. sw2: U6V10B015
id-page Ok
nfi area detection finished: Ok
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip-id: 0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007600AD0076 [04200000]
warning: NOR flash chip not supported or not detected
Initialize Done
Set baud...
921600
Set baud Done
Identification...
converting data...
done
protocol ver: 04
ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B19.BIN
ver. sw2: U6V10B19
ffs offset/size: 01700000/02900000
id-page Ok
structure: 2nd [standard] (or higher) generation
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
write core area 1 of 2...
write core area 2 of 2...
formatting...
Write Done
Finished, time used: 296 sec
Remove/Install battery now !
SAME PROBLUM BRO PLS HELP ME
Old 09-26-2007, 12:50   #5 (permalink)
Member: 503334
Sonork: 100.1590885
Thanks Meter: 173
I Have Got Five Pcs For Same Problum
Old 09-26-2007, 15:58   #6 (permalink)
Member: 187451
Thanks Meter: 163
Originally Posted by KASAM View Post
I HAVE ZTC ZT303.
You guys face this problem coz u dont read its full flash before formatting ffs and writing another firmware.now check with charged bettery.it will take 1 minute to power on.dotn use power supply.
Old 09-26-2007, 21:54   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@KASAM
here is detailed instruction, please, follow it step-by-step: http:///vbb/showthread.php?t=447277
Old 09-28-2007, 22:27   #8 (permalink)
Member: 154627
Thanks Meter: 3
I Need Pinout For Zt303(ztc)
Please Help Me
I Need Pinout Cable For Zt303
Old 09-29-2007, 14:22   #9 (permalink)
Member: 130995
Originally Posted by amir2202 View Post
Please Help Me
keyboard top
1.........12
1: Gnd
6: Tx
7: Rx
Old 11-04-2007, 07:25   #10 (permalink)
Member: 42408
Thanks Meter: 6
cannot find the similiar firmware....
phone:ZTC-ZT303
protocol ver: 04
ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B28.BIN
ver. sw2: U6V10B28
what firmware can i write to this phone????
thnaks
Old 11-04-2007, 11:38   #11 (permalink)
Member: 130995
phone:ZTC-ZT303
protocol ver: 04
ver. sw2: U6V10B28
thnaks
you can find similar firmware in support area: flashfiles\ChineseMiracle\_MT6228
please, before you flash your phone, make "read firmware" procedure before flashing and send backup_flash and backup_system_log files to [email protected]
Old 11-04-2007, 12:41   #12 (permalink)
Member: 42408
Thanks Meter: 6
my phone loading 100 % then off....
try all the step but still same problem....
-full back up
-format ffs safe and complete
-then write U6_PCB04_GPRS_MT6228_S02[1].U6V10B21__En_Fr_Es_Indonesia_Vn_Ru_Th_Cn.B4M.bin
- after that phone still loading 100% then off
please maybe another solution????
Old 11-04-2007, 12:50   #13 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
ZTC 313 pinout need...............
Old 12-17-2007, 23:33   #14 (permalink)
Member: 44031
hi
even i am looking for the same file
there are other files in the support area. but they do not end with no. 28
ie: U6V10B28.BIN.
can the files currently present in the support area ie: 15, 18, 20, ...... be used insted.
Old 12-18-2007, 02:59   #15 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
make full backup of your existing firmware and then is safe to try 15, 18, 20.
if they will not work properly- you can always return phone to original state by writing back your backup
New ZTC ZT303 pinout here! jawad8305 Chinese Cocktail 3 02-22-2009 06:22
New ZTC ZT303 pinout here! jawad8305 Infinity-Box 3 02-19-2009 23:34
New ZTC ZT303 pinout here! jawad8305 SpiderMan 2 02-19-2009 23:32
Repair configer fffff then phone off after 5/10 minutes jabed_net BB5KING 12 01-07-2009 10:21
ZTC ZT303 pinout. Raklm Chinese Cocktail 5 11-22-2007 13:52
Page generated in 0.32744 seconds with 10 queries
