Old 06-04-2007, 13:40   #1 (permalink)
paklink's Avatar
Member: 71321
Sonork: 100.1576579
Thanks Meter: 411
ChineseMiracle test pin outs
TO ALL FORUM MEMBER
DEU TO ALOT OF CHIENSE MOBILE IN MARKET ( SAME MODEL BUT DIFFRINT CONECTER & PIN OUTS) I DECIDE TO MAKE THIS POST
1: HERE ONLY POST TESTED PIN OUTS WITH COMPLETE DETAIL OF MOBILE MODEL (IF POSSIBALE THEN POST PHONE PIC TOO)
2: ONLY POST TESTED PIN OUT HERE DON'T ASK ANY PIN OUT IN THIS THREAD .
3: I POST 2 SAMPLE ( TESTED PIN OUTS ) HERE TO KNOW FOR ALL WHO POST PIN OUTS
4: DON'T SAY THANKS , OTHER WORD OR WRONG PIN OUOTS HERE ONLY POST TESTED PIN OUT
PIN OUTS FOR GRADIENTE GF950
KEYBOARD TOP
1.........14
7: phone Gnd (RJ45 pin 7,8)
8: Phone Rx (RJ45 pin 2)
9: Phone Tx (RJ45 pin 3)
OR BY PIC LIEK ATTACH TREND T100 PIN OUTS
THX ALOT FOR ALL & REQUEST TO MAKE THIS POST STICKY
Old 06-05-2007, 09:48   #2 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
do you have pinout standard for 2*12 ?
Old 06-06-2007, 01:46   #3 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
N95 PDA tested pin outs
connector_2x5_mini
standard pin count
_______________
/ 1 2 3 4 5 \
| 6 7 8 9 10 |
connector_2x5_mini
4: Rx rj45 pin 2
5: Tx rj45 pin 3
6: Gnd rj 45 pin 7/8
Old 06-12-2007, 12:02   #4 (permalink)
kasner's Avatar
Member: 56469
Thanks Meter: 136
connector_2x5_mini
standard pin count
_______________
/ 1 2 3 4 5 \
| 6 7 8 9 10 |
connector_2x5_mini
4: Rx rj45 pin 2
5: Tx rj45 pin 3
TNX. Very usefull. Tested 100%
BR Kasner
Old 08-29-2007, 13:51   #5 (permalink)
moorthy's Avatar
Member: 37523
Thanks Meter: 31
china nokia n95 pda 18pin out
china nokia n95 pda 18pin out pls help me
Old 08-29-2007, 14:43   #6 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,054
open phone check for rx tx and gnd at pcb..
you just need this only to connect phone.
Old 08-29-2007, 14:52   #7 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Much More to Read
Old 08-29-2007, 18:45   #8 (permalink)
samgsm's Avatar
Member: 478781
Thanks Meter: 44
I have one phone with 18 pin connector.
according to you I open my phone and find some points named like
RX_A, RX_B, TX_A, TX_B, GND, POWER_A, POWER_B, VBAT
THIS SIX POINTS ARE AS:
RX_A TX_A POWER_B POWER_A
TX_B RX_A GND VBAT
I CHECK CONITINUITY FROM CONNECTOR TO THESE POINTS
TX_A AND RX_A AND GND WAS CONNECTED TO CONNECTOR..
I CONNECTED MY RJ45 CABLE WIRES LIKE THIS
RJ45 NO2 POINT TO TX_A
RJ45 NO3 POINT TO RX_A
RJ45 NO8 POINT TO GND
AND I TRIED TO CONNECT ON INFINITY BUT IT IS NOT RESPONDING..
I used bettery and when i press and release power button there was a blink on tx
point of my infinity box...
Do u have solution for this?? or you have different way to repair??
Thanks
Old 08-29-2007, 18:56   #9 (permalink)
Sam-TheMaster's Avatar
Member: 182895
Sonork: 100.112022
Thanks Meter: 541
keyboard top...
1..........................18
1-2 GND
8- Tx
10- Rx
Check by alternating rx tx cause I didn't remarked perfectly cause that phone was not longer with me... I hope you will find out this usefull
for more testing U can open phone and find that points typed already as stanner austing told..
Wbr..
Old 08-29-2007, 19:43   #10 (permalink)
Member: 49752
Thanks Meter: 6,054
TX_B RX_A GND VBAT
Thanks
good u have found at pcb..
just invert tx as rx and rx as tx..
and tick on auto detect bualrate.
when its show u press power on press and hold power on untill its show u release power on botton.
Old 08-29-2007, 20:12   #11 (permalink)
david laborator's Avatar
Member: 228601
Thanks Meter: 56
looking for cect s560 standard connector 1X18 pinout , phone double sreen open like e700 1.3megapixel
thanx in advice
Old 08-30-2007, 14:56   #12 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 35
Paklink, i've waited for u to come online so i can order the cables but can't get u online. I want to give u info of my purchase, Pls if u can't come online, give me a phone number to which i can reach u, so i can order my chinese miracle cable set.
Old 08-30-2007, 18:27   #13 (permalink)
paklink's Avatar
Member: 71321
Sonork: 100.1576579
Thanks Meter: 411
see ur PM so bz these days so plz send me email
Old 08-31-2007, 07:56   #14 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 31
hello Gaurav_Radadiya
many time i post this solution u must serch
n95 pda 1x18 pin
1,2,---ground
7-----tx
9-----rx
Old 08-31-2007, 08:08   #15 (permalink)
Member: 182895
Sonork: 100.112022
Thanks Meter: 541
n95 pda 1x18 pin
1,2,---ground
7-----tx
9-----rx
May be my counting problem! Cause it was with me for only 4-5 minutes...
Well easy solution Use ETBOX Cable of Spice S500 model..
Use it with infinity and check out.. its wrking!
By the way I repaired that phone with Points to direct PCB and successfully solved my problem
With Best Of Luck!
<< N95 8GB Tested Pin-out >> jhepoy_org Infinity-Box 8 03-20-2009 15:57
Tested M8380 pin out successfully format LogoMan Infinity-Box 1 01-22-2008 21:56
Sharp Gx30 Pin Out Tested Look sunnyc Sharp 4 10-07-2004 07:57
Pin out Test point Toshiba Ts21i xareme Various 5 04-07-2004 14:48
Samsung cable pin-out - tested m.com Samsung Flashers, Software, Firmware. 5 02-23-2002 11:50
Page generated in 0.45991 seconds with 9 queries
