08-31-2007, 07:21 | #16 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: India
Member: 182895 Status: Offline Sonork: 100.112022 Thanks Meter: 541 | Quote:
S560 Q618 Nokia-N73 Nokia-N83 Nokia-N95 Nokia-730 LCD ------------------------------ /1 2 3 4 5 6 \ 7 8 9 10 11 12 6: Tx 7: Rx 8: GND Not Tested By Me.. But Check and post results..! Take Care With Best Of Luck | |
09-02-2007, 20:05 | #18 (permalink) |
Freak Poster Join Date: Sep 2006 Location: syria damascus
Member: 348451 Status: Offline Thanks Meter: 2 | here is the 6300 pinouts it's inside the phone under the mmc holder on the left u wiil see two small points it's writtin near every one of them the tx and rx don't try too find pinouts from the usb ports cauze u wont find any |
09-02-2007, 20:07 | #19 (permalink) |
Member: 348451 Status: Offline Thanks Meter: 2 | here is the n96i pinouts it's in the phone from the upper face of the board under the keypad sticker on the left u'll find 5 points it's writtin above every one of them the tx and the rx don't confuse it with power point or u will damage ur box ok |
09-02-2007, 20:11 | #20 (permalink) |
09-21-2007, 18:01 | #26 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 238245 Status: Offline Thanks Meter: 45 | nice post but i need mpeg4 pinout pls help me [email protected] |
09-22-2007, 18:28 | #27 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. |
09-22-2007, 18:54 | #29 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
<< N95 8GB Tested Pin-out >> | jhepoy_org | Infinity-Box | 8 | 03-20-2009 14:57 |
Tested M8380 pin out successfully format | LogoMan | Infinity-Box | 1 | 01-22-2008 21:56 |
Sharp Gx30 Pin Out Tested Look | sunnyc | Sharp | 4 | 10-07-2004 06:57 |
Pin out Test point Toshiba Ts21i | xareme | Various | 5 | 04-07-2004 13:48 |
Samsung cable pin-out - tested | m.com | Samsung Flashers, Software, Firmware. | 5 | 02-23-2002 11:50 |
