Old 06-09-2010, 09:55   #1 (permalink)
Member: 846872
Thanks Meter: 109
How to unlock E66 chinese
Hi,
It's the first time I'm using my Infinity Box, and have got an E66 Chinese, but don't know witch cable to use.
I've got the standard cables that comes with the box.
Modell E66
TYPE: KT257
Old 06-09-2010, 12:47   #2 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
did u have PinFinder??
if yes choose the right cable for your phone then search for it with pin finder u can find Pind finder guide some where here , if u found the pinout ( Rx , Tx ) then from Chinese Miracle do SP-Unlock
u can check here also:
http://forum.gsmhosting.com/vbb/f425...2/#post5926184
Old 06-09-2010, 18:15   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
1. please post connector type.
2. are you sure that this is mt62xx MCU based phone?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
3. do you have Pinfinder?
waiting answer to all 3 questions
Old 06-09-2010, 23:09   #4 (permalink)
Member: 846872
Thanks Meter: 109
hello!
1. Connector type Micro USB.
2. I've to try it later on I don't have access to the phone now. but I think it is.
3. I don't have pinfinder.
Old 06-12-2010, 13:26   #5 (permalink)
Member: 148515
hello!
what connector is used in this phone?
do you have multimeter for measuring voltage?
Old 09-01-2010, 03:10   #6 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 48
Sr i have this model
Sr i have this model in my hand its supported by infinity by tested *#0044# but i can find the pinout in pinfinder, conector is L05B.
How is the measure voltaje procedure?
Old 09-01-2010, 11:14   #7 (permalink)
Member: 148515
hello!
you must search for test points on PCB.
here is how this can be done:
http://forum.gsmhosting.com/vbb/5530460-post2.html
Old 09-06-2010, 04:44   #8 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 48
Voltages measured
Sr:
See the picture with voltages in the conector, only find 2.8v i confused...
B.R.
Old 09-06-2010, 05:59   #9 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 48
Sorry Image not uploaded in previous post
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Old 09-06-2010, 23:22   #10 (permalink)
Member: 148515
hello!
you have marked test points.
what could be easyer?!?
solder 3 wires.
box Tx pin to phone URX
box Rx pin to phone UTX
box GND pin to phone GND
thats it!
Old 09-07-2010, 03:29   #11 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 48
I try before and not conected, i cross Tx, Rx too...
Old 09-07-2010, 22:28   #12 (permalink)
Member: 148515
hello!
if you sure that phone is MT62xx MCU- then it should connect.
can you make photo of rj45 cable with connector visable?
i will check if you are using correct pins.
picture must be in good quality.
same as mine here:
http://forum.gsmhosting.com/vbb/f296...-cable-386780/
so i could count pins and see colurs
Old 10-25-2010, 05:30   #13 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 48
Hi Sr, this the phone CPU MT6225A 0844-AHBAL KTSK7337 BR
Old 10-25-2010, 19:28   #14 (permalink)
Member: 148515
hello!
same as mine here:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.22759 seconds with 10 queries
