09-03-2007, 22:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: TEMA
Member: 42981 Status: Offline Sonork: 1583521 Thanks Meter: 9 | chinise cables Device: Autodetect Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 4 sec Remove/Install battery now ! |
09-04-2007, 13:06 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's cable problem, wrong pinout. You must use correct cable and select correct COM port. about cables/pinouts: Please, use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
UstPro2 Cables | baljitsb | UST Pro II | 2 | 03-30-2010 13:35 |
NEC n930 usb cable and charger needed | przemekj | NEC | 0 | 03-29-2010 15:21 |
chinise CETC N99i what cable use | ayhen42 | Chinese Cocktail | 1 | 11-29-2007 10:59 |
