10-15-2009, 14:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | chip size mismatch i have mtk 6223 based phone witch restart when i try to format than this error is coming and i reball flash ic and reball cpu but same problem flash chip is from samsung k5l2833ata-af66,udo3sp2 it can read ffs area byt ccan't make ffs COM4 [VCP0] selected module v2.92 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? Boot ... Press and HOLD Power button now ! error: boot initialization step #3 failed: error: boot initialization step #2 failed: A0 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8939:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 05 ver. sw 1: QING_S03_PCB01_GPRS_MT6223P_S00.QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM.BIN ver. sw 2: QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed error: no any expected answer error: flash erase error: 00E00000 error: wrong answer: 6E error: erase #E2 Finalization Fail Finished, time used: 59 sec Remove/Install battery now ! |
11-08-2009, 10:41 | #3 (permalink) | |
I was a problem with new type of phone hardware. Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar It was tested with new flash chip types. Waiting for your results. | |
11-09-2009, 12:56 | #4 (permalink) | |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | Quote:
11-10-2009, 09:59 | #5 (permalink) |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | thank your sir your very hard work in new chiness mirecale 2.97 i had done alfatel c500 with format ffs thank you sir i love infinity team here is full log of formating prosiser COM3 [VCP0] selected module v2.97 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8939:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #02 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #03 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 05 ver. sw 1: QING_S03_PCB01_GPRS_MT6223P_S00.QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM.BIN ver. sw 2: QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: QING_S03_PCB01_GPRS_MT6223P_S00.QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM__ffs ... file saved: D:\Documents and Settings\Patel telecom\Desktop\QING_S03_PCB01_GPRS_MT6223P_S00.QI NG-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM__ffs _20091110-142251.B0E.bin flash: EC240200000000:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done Finished, time used: 122 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Help me! chip size mismatch! | Sergey_S | Infinity-Box | 1 | 10-27-2009 17:12 |
Size Mismatch | eurka | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-05-2009 10:50 |
Flash size mismatch | Bmt_HR | Smart-Clip | 0 | 12-20-2005 07:55 |
what is the size of m55 flash chip? | MrGoo mobile | E-Gold Based Phones | 6 | 01-30-2004 23:18 |
What is type and size of flash chip in GD55? | Bogi | Panasonic | 4 | 03-30-2003 17:35 |
