04-25-2006, 12:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 43
Member: 130055 Status: Offline Thanks Meter: 1 | cl75 no service after unlock? |
04-25-2006, 18:10 | #4 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: http://www.halong.vn/ Age: 33
Member: 45580 Status: Offline Thanks Meter: 48 | Quote:
04-26-2006, 06:15 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's no need to make any eeprom repair procedure. During unlock no any calibration data can be damaged, so its not bad idea to check phone hardware first, try to make 112 calls, check network band selection and maybe make reset defaults. |
04-26-2006, 10:52 | #10 (permalink) |
Member: 130055 Status: Offline Thanks Meter: 1 | oke now i know more i putted new main sw on it now i can call but i did not flash lp and map because i did not know what files exactly to flash an this moment i fashed maincl75_100_main.21m now i thin when i flash correct lp and map it will be ok but wich lp and map i need to flash???? please infinity support do you have msn or can you give me file name so i can download it from support site? |
04-26-2006, 12:27 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, look at "Flash Files Description" document in support area. You can get more than detailed info about flash files and what LP/Map?Main to use together. |
04-26-2006, 17:44 | #12 (permalink) |
Member: 130055 Status: Offline Thanks Meter: 1 | after flashing with this:CL75_100D_Main.21M CL75_100_LP01L2707_Catalan_Fr_De_Gr_It_Pt_Br_Es_Tr .21P CL75_Map_DF-M22.10.21F and repair eeprom with file on supp site phone works perfect only.when the lcd light goes off it doesn't go on anymore you can make calls and recieve calls but display will not work. when take out battery display will work again untill exactly same moment when the light goes off. maybe when i flash it with the other main flash will it work? |
04-26-2006, 18:13 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Try to flash with 301d. As I can understand CL75 have different HW and in some cases 301d can helps. File size difference - check this link: http://forum.gsmhosting.com/vbb/showthread.php?t=287829 101: old format 301: new format |
CL75 No Service after unlock | PIMP123 | Infinity-Box | 5 | 05-09-2008 17:55 |
L 7 no service after unlock | jazzcomms | Motorola P2k | 7 | 09-05-2007 09:27 |
x495 no service after unlock | gsmservices | SYSOL Platform | 4 | 11-19-2006 12:15 |
L6 no service after unlocking | neppra | Motorola P2k | 4 | 07-19-2006 13:53 |
Siemens SX66(BlueAngel) No Service After Unlock, Plz Help!! | citifone | HTC & PDA WM( With Touchscreen) | 5 | 01-05-2006 17:15 |
