09-29-2006, 11:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | CL75 problem connecting to software after.. I have a CL75 which was freezing at startup logo. I Flashed the phone with CL75_100D_Main.21M.bin firmware only. After that phone is dead. Now the phone will not power up or connect to software agian. Its stuck on 'Power on phone ' message. When I put cable into phone, phone vibrates but do not responds to power button as it did before. May be I should have flashed all Firware/map/lang files together. Is there anything I can do to coonect to sftware agian?. I know cable is ok as I used the same cable to flash the firmware first time. Attached log file of all I have done so far. br msa ---------------- Log opened: [29/09/2006] [10:22:21] App: QModule.exe Loading data, wait... [Infinity Box] v2.15 S/N: ****:0*** Standard firmware detected Wait... Current device: Panasonic GD55 Done Current device: Siemens CL75 COM1 selected Device: Siemens CL75 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 19 sec COM1 selected Device: Siemens CL75 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: Backup_eeprom_unlock-1_2006-9-29_10-24-53.21E.bin file saved: Backup_eeprom_unlock-2_2006-9-29_10-24-53.21E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 Format file system Done Write... Preparing... area requested/selected: 02/03 Finalizing... area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 31 sec Loading file [version 01]... CL75_100D_Main.21M.bin Loaded COM1 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Write: Firmware Skip: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write: Firmware area requested/selected: 01/03 Write Done Finished Remove/Install battery now ! Time used: 1407 sec Loading file [version 01]... CL75_Map_DF-M22.10.21F.bin Loaded Loading file [version 01]... CL75_100_LP02L2707_Dk_Nd_Fi_Fr_De_Nw_Sw.21P.bin Loaded COM1 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Skip: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Err: wrong answer, error#01 Boot Fail Finished Remove/Install battery now ! Time used: 103 sec Loading file [version 01]... CL75_100D_Main.21M.bin Loaded COM1 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Err: wrong answer, error#01 Boot Fail Finished Remove/Install battery now ! Time used: 17 sec ---------------- Log opened: [29/09/2006] [11:13:26] App: QModule.exe Loading data, wait... [Infinity Box] v2.15 S/N: ****:0*** Standard firmware detected Wait... Current device: Panasonic GD55 Done Current device: Siemens CL75 Loading file [version 01]... CL75_100D_Main.21M.bin Loaded Loading file [version 01]... CL75_Map_DF-M22.10.21F.bin Loaded Loading file [version 01]... CL75_100_LP02L2707_Dk_Nd_Fi_Fr_De_Nw_Sw.21P.bin Loaded COM1 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! |
09-29-2006, 12:27 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Use other flash files set from support area. CL75 has differen HW configuartions and downgrade can be not good in some cases. As about PC-phone connection problem: just try again. CL75 can't be killed permanently and can connect to software even if flash chip totally erased. |
10-01-2006, 12:24 | #3 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Sorry for delayed responce . Thanks for quick your reply which I saw as soon as you posted but did not get time to reply, sorry for that . I did flash the phone with different flash files and phone was still freezing at start up, so I think it has hardware fault. As for phone not conne4cting, the battery was flat . thanks msa |
problem connecting to mmode after unlock rzar v3 | JessyLou | Motorola Hardware Repair | 0 | 03-28-2006 09:29 |
MYx2-2 unable to connect to software???? | ReyTech | SAGEM JTAG UNLOCKER | 2 | 08-13-2005 09:12 |
Siemens C45 dont connect to software | lanzalotta | Siemens Hardware Repair Area | 14 | 01-16-2004 15:18 |
T230 unlocking. Problems connecting to software | EDV11 | Cruiser Suite | 11 | 12-21-2003 02:01 |
