06-15-2009, 14:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: india
Member: 345698 Status: Offline Thanks Meter: 46 | classic 7610 fiormat successful method 1) if u have pinfinder select manula pin out 3 is RX and 4 is tx 2) open PMmodule02.exe 3) then do format show the result COM8 [VCP1] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090615-174245.70E.bin reading... file saved: D:\Program Files\InfinityBox\PModule02\file_system__20090615-174439.70F.bin Check space Ok Write... flash: BF7353FFFF0052:00008500000000 Erase: ffs Write Ok Close... Close Ok Restart... Restart Ok Finished, remove/install battery now ! Time used: 141 sec method 2 1) if u have padfinder then open padfinder tool 2) then select PHONE PLATFORM is philips TAT MODE 3) click search then u got a pin outs else u select manual pin outs 3 is rx and 4 is tx 4) click unibox mode 5) open PMmodule02.exe 6) select comport use in padfinder 7)then do format COM8 [VCP1] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090615-174245.70E.bin reading... file saved: D:\Program Files\InfinityBox\PModule02\file_system__20090615-174439.70F.bin Check space Ok Write... flash: BF7353FFFF0052:00008500000000 Erase: ffs Write Ok Close... Close Ok Restart... Restart Ok Finished, remove/install battery now ! Time used: 141 sec |
06-15-2009, 14:17 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote: THANKS FOR SHARING NICE INFORMATION NO DOUBT INFINITY IS BEST OF THE BEST BOX |
Zte Classic 7610 Unlock Done... | jmzboudh | Infinity-Box | 9 | 12-12-2010 20:55 |
classic 7610 | pethu | Infinity-Box | 0 | 06-15-2009 14:10 |
6120 Classic Unlock Done Successfully! | Shahzad. | Universalbox | 0 | 04-04-2009 13:03 |
classic 7610 booting problem | rajesh_sahil | Infinity-Box | 1 | 02-01-2009 15:41 |
classic 7610 | zandoo | Various CDMA/TDMA Cell Phones | 1 | 01-12-2009 08:40 |
