07-10-2015, 12:06 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Clone IPhone6 Plus ATE Signaling Test.. while trying to writing security device entered to this mode and not exiting..i tried all key combination.. Code: Start at : [10.07.2015 / 12:06:16] Operation : Check / Read Info [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B4A5330304D0812B376C67F17 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004B4A5330304D0812B376C67F17 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : keytak72_cwet_lca ProdModel : keytak72_cwet_lca Device : keytak72_cwet_lca AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : 604755_550.3G.EN.CN.V30.C12 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [10.07.2015 / 12:06:30] Start at : [10.07.2015 / 12:06:58] Operation : Repair Security [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... |
