11-26-2010, 10:08 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | club c100 infinoen phone sim faild show solution with infinity here is logs COM20 [Serial2] selected module v1.78 Device: Trend-T101 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-static_20101126-135642.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-security_20101126-135647.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-complete_20101126-135704.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 38 sec Remove/Install battery now ! thanks infinity team |
The Following User Says Thank You to shakeel145 For This Useful Post: |
11-26-2010, 18:23 | #3 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | withe out sim ok when insert sim and on phone searching the signal and its say sim faild i formatffs with infinity its ok thanks infinity |
10-26-2011, 16:44 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Today I Tried With Ur Given Procedure Format ffs Ok But Problem Not Solved | |
11-01-2011, 17:54 | #12 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Yes Thanks For That. But I Have To Search Too Much For Solution So Plz Make It Easy For Others. So Add This Model In Infinity For Direct Solution. Some Other Persons Have Uploaded Its Backup Plz Add On Supports As Well......... |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
