10-19-2015, 16:07 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Club Mobile A90i SPD6531 Not support! Format Not support! Code: Operation : Read User Code [ v1.05 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Check data... Can take some time User Code : 1234 Done! Elapsed: 00:00:13 Code: Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Please, send FlashDump + log to support! Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.05 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6716_PDA HWInfo : SC6716_PDA Compile : 06-25-2015 21:09:10 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_06252015210910.bin Done! Elapsed: 00:01:33 SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_062 52015210910 |
10-19-2015, 16:16 | #3 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Solved problem Format Done Thanks for your advise Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:29 |
