Old 08-29-2017, 15:24   #1 (permalink)
ramrajbhopal's Avatar
Member: 768205
Thanks Meter: 45
cm2 card update error
Dongle can't be found:
Card with specified AID is not found
during update firmware card dead how to solve this problem
Old 08-29-2017, 21:24   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
- Run CardID software - http://www.infinity-box.com/support/?r=7
- Select Card-Reader
- Click to "Read" button
DO NOT send screenshot/video but copy/paste text from software window !
Old 08-31-2017, 09:22   #3 (permalink)
Member: 768205
Thanks Meter: 45
Originally Posted by InfinitySupport View Post
Hello,
Card-Reader: FT SCR2000 0
ATR: 3B759400006202020201
Card Manager: A0000000030000
SerialNumber: 000355A9
ROM:
Integrated Circuit Fabricator: 4090
Integrated Circuit Type: 0062
OS:
Identifier: 0011
Release Date: 0202
Release Level: 0100
EEPROM:
Fabrication Date: 0017
Serial Number: 000355A9
Batch Identifier: 0000
Module Fabricator: 1942
Module Packaging Date: 0017
IC Card Manufacturer: 1943
IC Em******* Date: 0017
Pre Personalizer: 1944
Pre Personalization Date: 0017
Pre Personalization Equipment Identifier: 0000C111
Personalizer: FFFF
Personalization Date: FFFF
Personalization Equipment Identifier: FFFFFFFF
m_iopCard.Serial: 000355A900001942
Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 )
Old 09-02-2017, 00:14   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
ROM:
OS:
Identifier: 0011
Release Date: 0202
Release Level: 0100
EEPROM:
Personalizer: FFFF
As I can see dongle already updated well. Right ?
Old 09-12-2018, 14:47   #5 (permalink)
adnan sarwar's Avatar
Member: 450150
Thanks Meter: 53
SIR HELP ME
Card-Reader: Alcor Micro USB Smart Card Reader 0
ATR: 3B7D95000080318065B0831148C883009000
Card Manager: A000000018434D00
SerialNumber: 00087881
ROM:
Integrated Circuit Fabricator: 4250
Integrated Circuit Type: 3272
OS:
Identifier: 1291
Release Date: 6181
Release Level: 0700
EEPROM:
Fabrication Date: 1271
Serial Number: 00087881
Batch Identifier: 1032
Module Fabricator: 1292
Module Packaging Date: 1363
IC Card Manufacturer: 2003
IC Em******* Date: 1363
Pre Personalizer: 2004
Pre Personalization Date: 1363
Pre Personalization Equipment Identifier: 00000044
Personalizer: 0000
Personalization Date: 0000
Personalization Equipment Identifier: 00000000
m_iopCard.Serial: 0008788110321292
GP Version: 2.1.1
SCP Version: 1, Option: 5
Old 09-12-2018, 15:56   #6 (permalink)
Member: 1043909
Thanks Meter: 60,921
SIR HELP ME
ROM:
OS:
Identifier: 1291
Release Date: 6181
Release Level: 0700
EEPROM:
Personalizer: 0000
GP Version: 2.1.1
I suggest you to read answers instead of post the same problem in many threads !
Old 01-05-2020, 09:02   #7 (permalink)
Member: 235214
Sonork: 1661526
Thanks Meter: 5
Dongle is not found !!!
Infinity-Box CardID v1.09
Error when connecting Card in: Generic EMV Smartcard Reader 0
SmartCard API error #2148532326
The smart card is not responding to a reset.
Please help! Thank You.
Old 01-05-2020, 14:05   #8 (permalink)
Member: 148515
Hello,
Try to connect Dongle to another PC
Try to insert Smart-Card into another Card-Reader or Box (if you have it)
If problem still exist:
​- Remove Smart-Card from Card-Reader
- Clean Smart-Card contacts
- Try to use hot air gun and heat Smart-Card
- Insert Smart-Card back to Card-reader​
Result ?
Old 05-21-2020, 18:28   #9 (permalink)
Member: 2271997
=== DongleManager [Infinity] v1.80 [21-05-2020 22:52:23] ===
Box/Dongle type selected: Infinity-Box/Dongle
HWID: 00039F7B18201292
=== Process started: 21-05-2020 22:52:24 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Card returned error - 0000 at 551/8148
Error upgrading applets:
Disconnected
Old 05-21-2020, 18:41   #10 (permalink)
Member: 148515
Securing session...
Session secured ok
Upgrading dongle...
Disconnected
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 09-10-2020, 09:53   #11 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
help me
=== DongleManager [Infinity] v1.80 [9/10/2020 13:48:46] ===
HWID: 0102A4651C6A1292
=== Process started: 9/10/2020 13:48:46 ===
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
dongle is not reading serial number after just update giving this message
also dongle not working at any exe cm2mtk etc
after this i changed smart card reader its shown this text
=== DongleManager [Infinity] v1.80 [9/10/2020 13:59:05] ===
=== Process started: 9/10/2020 13:59:05 ===
Old 09-10-2020, 14:00   #12 (permalink)
Member: 1043909
Originally Posted by sameera View Post
help me
Hi,
Insert smart-card into your "Alcor Micro USB Smart Card Reader" now and update it ONCE.
Result ?
Old 09-12-2020, 08:18   #13 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
Originally Posted by YellowBoss View Post
Hi,
Result ?
=== DongleManager [Infinity] v1.80 [9/12/2020 12:16:01] ===
=== Process started: 9/12/2020 12:16:01 ===
Securing session...
Session secured ok
Upgrading dongle...
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 9/12/2020 12:16:14 ===
=== DongleManager [Infinity] v1.80 [9/12/2020 12:16:14] ===
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): D811A465
Firmware version: 0136.02
=> Activations:
- 00: Infinity-Box/Dongle v0136
=> Options:
- Infinity-Box/Dongle
thanks problem solved
Old 11-04-2020, 13:29   #14 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
cm2 ask me to update when i start software but when i try to udpate
it start process and ask me to wait 4 5 minuts, i waited more than it but not able to do so
now card not udpating at all...
kindly help me ...
=== DongleManager [Infinity] v1.80 [11/4/2020 17:33:36] ===
HWID: 000133B71F444082
=== Process started: 11/4/2020 17:33:36 ===
Write to https://www.infinity-box.com/support/?r=2
thanks in advance
kalpesh varia
Old 11-04-2020, 18:30   #15 (permalink)
Member: 1043909
kindly help me ...
thanks in advance
kalpesh varia
Hello,
- Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6
- Run Infinity DongleManager
- Update Dongle firmware
Alternative method:
- Insert Infinity Smart-Card into another Card-Reader (f.e. another dongle or box). Good result for today gives Alcor Card-Reader.
In case of problem DO NOT update card again but contact to support !
More info is here - https://www.infinity-box.com/support/?r=100129
Page generated in 0.33706 seconds with 8 queries
