Old 11-01-2018, 11:50   #1 (permalink)
Member: 2769481
Thanks Meter: 7
cm2 dear team help plz
tecno f3
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E58324D420131C59656B465
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xC40B0000
EMICFG_RET_FAILED
CodeDefine : DA_DEVICE_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:34
Reconnect Power/Cable!
Old 11-01-2018, 12:10   #2 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,977
You need DA file, check infinity support area for DA file or try using CM2 v2 r4
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 11-01-2018, 12:37   #3 (permalink)
Member: 2769481
Thanks Meter: 7
dear ysuf,,
thx ,, but cant find it
can u send link plz
Old 11-01-2018, 12:44   #4 (permalink)
Member: 1677653
Thanks Meter: 1,977
See below link for DA file
Old 11-01-2018, 12:51   #5 (permalink)
Member: 1677653
Thanks Meter: 1,977
Originally Posted by jackdanialed View Post
dear ysuf,,
can u send link plz
https://mega.nz/#!t7QxyIoZ!LbCj1bIzF...F4dbpZTnMo1rHc
Old 11-01-2018, 13:31   #6 (permalink)
Member: 2769481
Thanks Meter: 7
dear ,,this after use da file
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
Try Re-Install CM2MTK module!
Boot Error!
Operation Failed
Elapsed: 00:00:24
Old 11-01-2018, 14:44   #7 (permalink)
Member: 1677653
Thanks Meter: 1,977
Maybe u're doing something wrong.
Old 11-01-2018, 14:46   #8 (permalink)
Member: 1677653
Thanks Meter: 1,977
You can also use this tool to avoid DA file replacement issue
MANUAL BOOT ADDON V4 BY MUBARAK
Old 11-01-2018, 14:48   #9 (permalink)
Member: 2769481
Thanks Meter: 7
dear yusuf,,,
i tried another f3 and it work..
but this one didnt ..
so is it a hardware issue or what?????
thxxxx
Old 11-01-2018, 14:50   #10 (permalink)
Member: 1677653
Thanks Meter: 1,977
Power on phone,
Power off again,
Try reconnect.
If still the same thing,
Please try read emmc test and post log
Page generated in 0.34068 seconds with 7 queries
