11-22-2016, 08:51 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Cm2 Dongle Error while Read flash. I was reading flash from Qmobile and in the last it given an error and cm2 software and pc got hang. Read flash log. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454534454134010BC7D27A4385 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4AE4E [eMMC] : FLASH_CID : 700100454534454134010BC7D27A4385 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E2000000 [eMMC] : FLASH_UCP : 3616 MiB [eMMC 4 GiB] DEV RID : 0xB61EA29341A27B30399C01376180F4FE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : QMobile ProdName : QMobile W20 ProdModel : QMobile W20 Device : QMobile W20 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_GINR6580.WE.L_P21 [Read Ok] : preloader_a135.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img Can't create file and Access is denied. I unplugged the dongle. Now cm2 software is not opening on Windows 7. |
11-22-2016, 09:06 | #3 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | If i'm putting cm2 sim card into the infinity best reader but there different Error Dongle manager Log DongleManager [Infinity-Box] v1.67 [11/1/2016 12:30:18 PM] PC HWID: AFE53D58C650AEABAEA73CA5F329C5F0 Scanning... Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0101968120281292 Box/Dongle Serial No (S/N): - - - - - - - - Firmware version: 0132.02 "UK edition" status: Off Last launched Application: 0031 v.0122 => Activations: - 00: Main Infinity-Box/Dongle v.0132 In both readers cm2 software not opening. This was happen when I just unplugged dongle from pc while it hanged. |
11-22-2016, 11:08 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, What is your dongle serial number? Can you run any other CM2 software module? Do you intentionally deleted serial number or software can't read serial number- Quote:
Infinity Box Support Team. | |
11-22-2016, 11:51 | #5 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Bro everything was fine all happened because of my mistake that quickly I unplugged the dongle from pc when pc hanged now not any module is opening. After double click on any module just error dongle not connected. |
11-22-2016, 12:16 | #6 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | I have two dongles bro and im facing problem with same serial and dongle that team solved problem Few months ago in the previous post I can see serial number of cm2 is CE489681 |
11-23-2016, 04:52 | #8 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | @PASSIONATE_BOYS, Is sim card of my infinity dongle damage Or still there chance to repair? @hashim mobile, i must ask from the infinity team to follow the instruction before I should not do anything with my dongle. Because I don't want to get my dongle permentely blocked. |
11-23-2016, 08:37 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, You didn't answered my question in last post.- Quote:
And don't pm for problem, use open forum instead. Br. Infinity Box Support Team. | |
11-23-2016, 08:57 | #10 (permalink) | |
Member: 2452939 Status: Offline Thanks Meter: 256 | Quote:
If im changing reader then getting error dongle not found/connected as in screenshot. If using reader of Nokia infinity best dongle then this last error I posted here. And Sorry for the pm message. I tried today by installing new windows but the problem is still same. | |
11-26-2016, 18:57 | #14 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Yes bro this I need solution for my dongle to work and today I contact to Pakistani reseller he's said me to buy new dongle because mine damaged by serial. |
