12-31-2016, 10:04 | #1 (permalink) |
Freak Poster Join Date: Sep 2013 Location: india
Member: 2029413 Status: Offline Sonork: 100.1673967 Thanks Meter: 145 | CM2 Dongle UPDATE Error Pls Solve Code: ---------- Process started: 31-Dec-16 2:33:03 PM ---------- DongleManager [Infinity-Box] v1.67 [31-Dec-16 2:33:03 PM] PC HWID: 3D8C0BA6FB19C150AFA25B4A414EA977 Card-Reader: FT SCR2000 0 HWID: 0000C59B7D314082 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing check error: Card returned error - 6E00 at 0/117 |
12-31-2016, 12:37 | #2 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
very smart user always post error with your card sn then help you | |
01-04-2017, 19:32 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! |
01-30-2017, 09:42 | #13 (permalink) |
Freak Poster Join Date: Dec 2007 Location: trichy
Member: 651994 Status: Offline Sonork: n/a Thanks Meter: 62 | my cm2 update problem Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 1/30/2017 2:03:31 PM ---------- DongleManager [Infinity-Box] v1.67 [1/30/2017 2:03:31 PM] PC HWID: 63A7AD189947D176B835A7345918C501 Card-Reader: FT SCR2000 0 HWID: 0109868024881292 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
01-30-2017, 22:14 | #14 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
08-27-2019, 12:01 | #15 (permalink) |
Junior Member Join Date: Jul 2019 Location: phillipines
Member: 2918662 Status: Offline Thanks Meter: 0 | same problem how fix here logs : Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000DE8812BF4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): C223DE88 Firmware version: 0136.02 "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0136 === DongleManager [Infinity] v1.72 [7/15/2019 17:40:02] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000DE8812BF4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): C223DE88 Firmware version: 0136.02 === Process started: 7/15/2019 17:40:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing check error: Server answer:[0002] Client/Server protocol packet length is invalid |
