11-03-2018, 10:19 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: IRAN.IR ----عل
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Error Frp Huawei Y6ll (CAM-L21 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E02AD0642B31C73C8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4206AD02C87334B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0BAB475C2A5AA816E29050398929C339 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : CUN-L21 ProdModel : HUAWEI CUN-L21 Device : HWCUN-L6735 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : CUN-L21C578B126 SECURITY : IMEI_SW [1] : 864782037289194 IMEI_SW [2] : 864782037344767 BTMAC Addr : C894BBFC49A9 WiFi MAC : C894BBF6E7BE MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V42_P40_1_lwg _n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : GT9157 CAM [0] : ov13850_mipi_raw CAM [1] : ov13850qt_mipi_raw CAM [2] : ov8855_mipi_raw CAM [3] : s5k4h8_mipi_raw CAM [4] : imx219_mipi_raw CAM [5] : ov5670_mipi_raw CAM [6] : hi551_mipi_raw CAM [7] : gc2355_mipi_raw CAM [8] : sp2508_mipi_raw CAM [9] : ov2680_mipi_raw LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:09 Reconnect Power/Cable! ????? 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E02AD0642B31C73C8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4206AD02C87334B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0BAB475C2A5AA816E29050398929C339 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Format/Reset Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
11-03-2018, 10:21 | #2 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E02AD0642B31C73C8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4206AD02C87334B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0BAB475C2A5AA816E29050398929C339 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Format/Reset Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
11-03-2018, 10:21 | #3 (permalink) |
11-03-2018, 11:39 | #4 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | hi huawei not allow to format frp area install supplimentary package 1.58 repeat select huawei model may work if failed then need to wait for an update |
The Following User Says Thank You to kamal_singla For This Useful Post: |
11-03-2018, 13:34 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 change DA from Original setup and try with hold boot key this DA not work in FRP MTK_AllInOne_DA_v5.1624.16.07 use this DA |
