06-28-2017, 09:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | cm2 hangs when do frp operation in z2132 lenovo 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : 32882613 ID_BLOCK_I : 009470E1 ID_BLOCK_L : 96D17C0EBD74920EA890DC9112E41EF7 ID_BLOCK_L : 68DC65CD47721D67599B24330B1B6812 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! |
07-05-2017, 16:20 | #3 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, The Cellphone Is Lenovo Z2132 (ZUK Z2-Plus) Operation : Identify [ v1.13 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : EBB542D0 ID_BLOCK_I : 009470E1 ID_BLOCK_L : D3AE334BC231D14B15D7A1D251A95B8A ID_BLOCK_L : 470950E2925DC8880EA6F7DEDE2C57C5 Use CM2 Internal Loader |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-09-2018, 12:04 | #6 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: Ahmedabad, India Age: 34
Member: 2286149 Status: Offline Thanks Meter: 34 | Quote:
Here is log Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : A7DCB196 ID_BLOCK_L : 1554F98D38F71F8D2B1D5B149F679D74 ID_BLOCK_L : 9C208939BB86F1B3E54FD8E7E7F7BCEE Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! With 1.13 log.. Code: Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : A7DCB196 ID_BLOCK_I : 009470E1 ID_BLOCK_L : 1554F98D38F71F8D2B1D5B149F679D74 ID_BLOCK_L : 9C208939BB86F1B3E54FD8E7E7F7BCEE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! | |
02-10-2018, 03:02 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Maybe you could try attached files ... Try and post results. p.s. Make backup before playing. p.s.2 If you encounter errors, replace loader from folder "loader2" b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
02-10-2018, 06:27 | #8 (permalink) | |
Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : A7DCB196 ID_BLOCK_L : 1554F98D38F71F8D2B1D5B149F679D74 ID_BLOCK_L : 9C208939BB86F1B3E54FD8E7E7F7BCEE Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : A7DCB196 ID_BLOCK_L : 1554F98D38F71F8D2B1D5B149F679D74 ID_BLOCK_L : 9C208939BB86F1B3E54FD8E7E7F7BCEE Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! | |
02-10-2018, 20:37 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Or, if FRP was the issue - just flash attached files from my previous post. 10 seconds job. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
06-03-2018, 19:38 | #12 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Your Set Frp Already Removed Conect Wifi Do Next Zuk Models Need To Conect Wifi to go for home page |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
