Old 05-30-2016, 08:52   #1 (permalink)
Member: 2452939
Thanks Meter: 256
VGO TEl i250 Done By CM2SPD
All boxes failed but CM2 Success
Phone found! [ 26 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2 �Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : BY CM2 SPD 6531
Model Name : VGO TEL i250
ExtInfo Data : URDU
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_URDU__BY CM2 SPD 6531-VGO TEL i250.bin
Done!
The Following 2 Users Say Thank You to GSM SINDH For This Useful Post:
Old 05-30-2016, 09:03   #2 (permalink)
Member: 2452939
Thanks Meter: 256
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2 � Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok
Check data... Can take some time
User Code : 0000
Done!
The Following User Says Thank You to GSM SINDH For This Useful Post:
Old 05-30-2016, 10:09   #3 (permalink)
Member: 2452939
Thanks Meter: 256
Log of MiraMonkey Failed
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Please Hold BootKey(UP and DOWN),Insert USB cable
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Scanning USB Serial port...
SU2Serial Port: COM71
Connecting to Phone,Wait..
Done.
Infor: SPRD3
>>Initialize boot13...
Old 12-16-2016, 15:12   #4 (permalink)
Member: 1431853
Thanks Meter: 15
VGO TEL - i600 Jumbo Boot Key
Click Here
The Following User Says Thank You to malikshakeel09 For This Useful Post:
Old 05-21-2017, 06:23   #5 (permalink)
Member: 2688510
Thanks Meter: 7
plz upload file and boot key
plz share the file and indicate boot key
Page generated in 0.16833 seconds with 8 queries
