Old 10-29-2016, 16:59   #1 (permalink)
K-B MOBILE's Avatar
Member: 2574306
Thanks Meter: 265
CM2 IMEI Repair Problem Plz Help me
CM2 IMEI Repair Problem Select With CM2 Permenant Option Plz Help me
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 5200011541423133CF280642EFB2C8CE
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BAB13
[eMMC] : FLASH_CID : 1501005233314241420628CFCEC853EF
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xB6C1A699CAE09FC8F72B0F08AC09E09D
INT RAM    : 0x00020000
EXT RAM    : 0xC0000000 [3 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 354872070550128
IMEI [01] : 354872075550123
Set IMEI [00] : 353543656768779
Set IMEI [01] : 353545657687874
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 15 ]
Sync...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Reconnect Power/Cable!
Old 10-29-2016, 17:50   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,445
instal CDC driver and try again
Old 10-29-2016, 18:36   #3 (permalink)
K-B MOBILE's Avatar
Member: 2574306
Thanks Meter: 265
Missing Drivers in Device Manager MT65xx Driver can you share Perfect Drivers....
Old 10-29-2016, 19:17   #4 (permalink)
Member: 2082450
Thanks Meter: 1,435
Arrow
Hello,
Try this and post result
Download
The Following User Says Thank You to chandanps18 For This Useful Post:
Page generated in 0.19458 seconds with 7 queries
