01-12-2017, 17:28 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | CM2 MemoryTool : Full Control in your hands ( info & manual ) At now it available in QLM module ( rest modules on way )
SW support binary files, raw(original) firmware parts flashing, including sparse and e.t.c.
You NOT depend on need xml files and etc. Just do what you need here and now! Manual : After init MemTool and success connection you will see internal device structure. You can check every element manually ( i.e. empty or not, filesystem state for forensic and etc. ) Main Workplace overview : There is few fields for every part :
FILESYSTEM - means there is some of standard filesystems data present NONE - empty partition
DATA - means partition NOT empty
You can press "Cancel" to make field empty. If field is NOT set - partition will be ignored, if it selected for WRITE operation.
You can press "Cancel" to make field empty. If field is NOT set - partition will be ignored, if it selected for READ operation. Operations overwiev : 1. Read Selected Read selected partitions from device ( if RD FILE is set ) 2. Write Selected Write selected partitions to device ( if WR FILE is set ) AT EVERY operation SW will ask about accept operation! 3. Set WorkPath Set path for READ operations ( instead default one ) Useful for make full RAW copy or etc. 4. Memory Test Make FAST memory test ( Memory ReadOnly Test ) Test is completely safe, and not depend on selected partitions to avoid any users mistakes. 5.Init MemTool / Close Session Start / Close MemoryTool session. On close session device will be rebooted to charge/normal mode. 6. Main workplace window Here user can select need partitions for desired operations,, verify their state, set path for read and write data. MULTIPLE partitions selection possible with CTRL ( ony-by-one ) and SHIFT ( ROW between START SELECTION and END SELECTION ) keys holding on keyboard. |
The Following 95 Users Say Thank You to JayDi For This Useful Post: |
01-12-2017, 17:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Very intelligent ,hot world,s first usefull rocking job done by infinity team ,Salute to dear jaydi . |
The Following 4 Users Say Thank You to amn32 For This Useful Post: |
01-12-2017, 18:19 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Will activate WIPE and some more stuff and features after 1-2 version, depend on users expirience with current one. New QLM version will be on support today. |
The Following 21 Users Say Thank You to JayDi For This Useful Post: |
01-12-2017, 18:27 | #5 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | The most important thing is to see, how people will adopt this new stuff with ease. These operations are going to be very useful only if one can be familiar with it. |
The Following 2 Users Say Thank You to chandanps18 For This Useful Post: |
01-12-2017, 18:52 | #6 (permalink) |
No Life Poster Join Date: Sep 2012 Location: ISLD Age: 36
Member: 1814771 Status: Offline Sonork: 100.1621347 Thanks Meter: 350 | good job cm2 team , plz don.t forget Secured MTK BOOT same Like Huawei? |
The Following User Says Thank You to Afridi gsm For This Useful Post: |
01-12-2017, 18:53 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Users ask custom writing and so on - they got it | |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
01-12-2017, 20:54 | #8 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Oh, that's nice, looks great and usefull for forensics and data recovery. With this, there's no more need for rawprogram.xml creator since it's possible to just pick and write partition images manually as well, should be easier to work with LG based phones. Something i've been waiting for, good job. We're limited to your loaders, right, as long as they support the phone, we're able to access the device? Any chance to maybe add ability to use own loader, just in case if there're a "custom" shipped with firmware or someone wants to try experimenting? Also, i have to ask if there's any chance to support Samsung, SONY, HTC phones with that, at least for data reading, maybe in the future? |
The Following 5 Users Say Thank You to KrzychuG For This Useful Post: |
01-12-2017, 21:05 | #9 (permalink) |
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello all, Here is the PDF link to download the same manual as in post no 1 for offline use any time. Hope it will help someone. View & Download |
The Following 12 Users Say Thank You to chandanps18 For This Useful Post: |
01-13-2017, 02:14 | #11 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | hope that this will support samsung device i have accidentally erase the file with CWM and now only qualcom detection it says infinity can detect the device but CPU is not supported hop you will support samsung device so that i can revive this device. |
The Following User Says Thank You to dyo For This Useful Post: |
01-13-2017, 04:46 | #12 (permalink) | |
Enough to make dummy rawprogram.xml, with 1 line and put in it folder nedd firehose_loader. Select in flash tab. SW will use it by default. Or use ready/similar/"only for own use and not for share" fw. Just select it in flash tab. Can add separate "use own FH" button as well. But not think about more entropy will be good We add new model lines and types in every update. Who knows. | |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
01-13-2017, 06:47 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | is it possible to flash to add protect imei and calibration data during flash and imei repair must be added |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
01-13-2017, 09:25 | #14 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | LYF in testing again- Memory testing- Modem partition reading- Modem partition writing- Br. Infinity Box Team. |
The Following 6 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
01-13-2017, 10:17 | #15 (permalink) |
Freak Poster Join Date: Dec 2011 Location: rajasthan,india
Member: 1705399 Status: Offline Thanks Meter: 81 | simply which condition of handset is required for this tool this tool is like for person how is software enginer my quistion is which condition of handset is required for this tool i am really simple user and this tool and its function is not understand dont laugh please |
The Following 5 Users Say Thank You to jitendra 1980 For This Useful Post: |
