06-29-2019, 17:26 | #1 (permalink) |
Insane Poster Join Date: Dec 2014 Location: PARADIS
Member: 2309100 Status: Offline Thanks Meter: 8 | cm2 MT2 It does not open I removed and reinstalled It automatically becomes not working I do not use a virus control Also do not use cracks Firmware Version: 0138; Registered: 29-Mar-2017; Expired: 27-Mar-2021; Support: Active |
06-29-2019, 18:40 | #2 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Pakistan
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | Delete setup reinstalling working fine... any time.. opne delete reinstalling.... on solution infinity team... same problem bro ..... |
The Following User Says Thank You to haseebkakar For This Useful Post: |
06-30-2019, 07:20 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
1. If you have "Fault.bin" file inside Cm2 Mt2 folder attach it here 2. Uninstall usb sharing /sniff/monitor/debug softwares (like flexihub etc.). 3. PC is infected with virus, as a result CM2 files (exe and/or dll) become changed or damaged or some strange files are in folder with CM2. Solution: Scan Pc with a trusted antivirus. 4.Delete CM2 Affected folder completely and re-install it. | |
The Following User Says Thank You to Kirumira For This Useful Post: |
07-01-2019, 13:35 | #7 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Pakistan Age: 24
Member: 2788598 Status: Offline Thanks Meter: 70 | uninstall flexihub and usb redirector then reinstall cm2 mtk it's not hard to click thanks button |
The Following User Says Thank You to Amar Ali07 For This Useful Post: |
07-02-2019, 01:01 | #9 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | In past i have same problem, i have solved restoring the windows for example 15 days ago , and software starting working , i do the jobs and then cancel the restore and software continue working. I know this is a strange solution but solved when i have faced same problem. |
The Following User Says Thank You to ct3im For This Useful Post: |
07-02-2019, 15:43 | #11 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, -Do you see fault.bin file inside installed folder? -Scan your pc once with some free antivirus and remove whatever malware, virus, etc found. -Download fresh setup from support area, uninstall current version, delete CM2MT2 folder and then reinstall setup. -Uninstall any kind of usb sharing, debug, spyware, etc software from your pc if present. Post result. Br. Infinity-Box Team. |
07-02-2019, 22:09 | #12 (permalink) | |
Member: 2309100 Status: Offline Thanks Meter: 8 | Quote:
my laptop as good not have any virus have many box and dongle working just mi probleme with MT2 other working good i | |
