11-19-2018, 19:37 | #1 (permalink) |
Registered User Join Date: May 2006 Location: ROMANIA - BISTRITA Age: 44
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | doogee mix 6g/64gb nvram & sec boot file |
11-19-2018, 22:10 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | Original Factory ROM file : 18-02-02 t900a-dg-a59-63m-hd-512g48g-bom6-3m-n-tee-cts_DOOGEE-MIX-Helio_P25-20170818.rar (6/64Gb) There is no special loader for doogee, all you need to do is Hold volume up button and connect your phone to PC via USB cable. Pay attention to preloader compatibility on doogee phones, or, to be sure not to make it a brick - do not flash preloader. p.s. Enable checksum check on flashing. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
11-20-2018, 03:10 | #3 (permalink) |
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Operation : Repair Security [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+SEL BROM : BOOTROM MODE : 0_base : BASE_v1816 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] EMMC: 90014A484347386134A207D3D4245459 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 2B8281C3CD6CB9D026DDC2B89EB493 DA : USB : FULL-SPEED Boot done! NVRAM check : Failed! NVRAM empty! NVRAM condition BAD! Impossible to continue! Done! Elapsed: 00:00:23 Reconnect Power/Cable! imei is empty , nvram empty |
11-20-2018, 23:48 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | Try to write attached nvram file via memory tool, and try repair afterwards. b.r. ALex
11-22-2018, 12:22 | #5 (permalink) |
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation Write Memory Write selected partitions [1] [0] Write partition : NVRAM Write from : C:\Users\QGSM\Desktop\doogee mix\DOOGEE MIX nvram work\nvramwork.img ERR : 0xC002002A ERR : SEC_IMG_TYPE_MISMATCH ERR : 0x00500000|0x00500000 Shutdown MemoryTool due fatal error Error : Failed to write data! Connection ( or secured region??? ) problem! Check cable, battery, connection and drivers! Reconnect Power/Cable! |
11-23-2018, 01:17 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,772 | Last hope - MTK SN Write tool instructions : Quote:
and attach here for further helping somebody else with same problem. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 11-23-2018 at 01:25. | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
