Old 04-28-2015, 21:48   #1 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
CM2 MTK v1.18 [Test]
Hello. Not full list of changes :
  MediaTek SP Platform
- MTK Flash Engine:
 - Flash Engine rewritten.
 - MT6575/6577  Factory Firmware Flashing enabled
 - MT6583/6589 Factory Firmware flashing enabled
 - MT6582 Factory Firmware flashing improved
 - MT6575/6577 Erased phones support activated
 And other important bugfixes for all supported platforms
 CPU supported now for Factory FW flashing: MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT8127, eMMC only
- Factory FW reading improved
 - MT6575 supported (eMMC)
 - MT6577 supported (eMMC)
 Allow read complete firmware with all mandatory parts as factory one!
 Some improvements for specific models support on different CPU's
 CPU supported now for Factory FW Reading: MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT8127, MT6592, MT83xx eMMC only
- SP Unlock operations improved
 - Read Codes now read both SIM codes for DualSim phones
 - Direct Unlock improved
- Service operations improved
 - "Fix Unknown BB" improved ( some NAND problems fixed )
 - Pattern Lock reading improved ( some NAND fixes )
 - Flash Init completely revised
  . MT6575/MT6577 supported
  . MT6589 support improved
 - "Init Preloader" improved , MT6575/MT6577 support activated
 - Flash Init completely rewritten for "Init Preloader" , Factory FW flashing , Flash (Dump) writing
 - Identify now possible with "Read All Info" for MT6575/MT6577 eMMC phones
 - Alcatel "ProInfo" operations improved
  MediaTek FP Platform
- MTK 652A/MT6260/MT6261 Read User Code improved
  MediaTek All
- Other
  FlashID Database updated
  FullFlash Read/Write revised for MT6575/MT6577
  Improved CompileInfo extraction
  Bugfixes and improvements
Link (exe only) : CM2MTKv118
Download and replace exe in current CM2MTK folder.
Interest to check reports with MT6575/MT6577. Factory FW read and flashing.
Interest to check reports with MT6589. Factory FW flashing.
FlashInit completely revised. Please, check "Init Preloader" and factory FW flashing on erased phones, which was not work before.
The Following 3 Users Say Thank You to Dzirt For This Useful Post:
Old 04-28-2015, 21:56   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
MT6575/MT6577 : Connect phone with damaged/erased/overwritten bootloader/dsp without opening phone and short TP and rest useless things.
1. Remove battery.
2. Press and hold : VolUp and VolDown keys.
3. Insert USB cable.
4. While holding side keys - insert battery.
Some times operation need repeat 2-3 times ( last step only - reinsert battery fast ). Success connect - 5 from 5 samples ( doesn't have more on hands ).
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Old 04-29-2015, 04:51   #3 (permalink)
ngocdiemmobile's Avatar
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 167
i have modem mt6253 need to support
Old 04-29-2015, 05:15   #4 (permalink)
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 167
mtk 6572 read not ok
Operation : Read Flash [ v1.18 ]
Wait for phone...
Phone found! [ 40 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Not supported FlashType for this operation yet
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Old 04-29-2015, 05:16   #5 (permalink)
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 167
mt6575 read ok
Start at : [4/29/2015 / 10:56:41 AM]
Wait for phone...
Phone found! [ 40 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Stat : v3.2 on BBID : 0x84
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594812A10DC2249F0B
[eMMC] : FLASH_LEN : 0x00000000E7000000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
MT657x Old CPU : Skip Initial Info read
[Image Ok] : preloader_s560_row.bin
[Image Ok] : DSP_BL
[Image Ok] : MBR
[Image Ok] : EBR1
[Image Ok] : lk.bin
[Image Ok] : boot.img
[Image Ok] : recovery.img
[Image Ok] : secro.img
[Image Ok] : logo.bin
[Image Ok] : system.img
[Image Ok] : cache.img
[Image Ok] : userdata.img
[Image Ok] : fat.img
Brand : Lenovo
ProdName : S560
ProdModel : Lenovo S560
Device : S560
AndroidVer: 4.0.4
MTKxCPU : MT6577
MTKxPRJ : ALPS.ICS2.6577.SP.V1.20120605
[ScatCFG] : MT6577 / V1.0.0 / s560_row / EMMC
FW Size : 551 MiB
Scatter saved to : C:\Users\nhatgia\Desktop\MT6577__Lenovo__Lenovo S560__S560__4.0.4__ALPS.ICS2.6577.SP.V1.20120605\
Old 04-29-2015, 05:30   #6 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
6571 nand
Operation : Check / Read Info [ v1.18 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
NAND_ID : 002C00BC009000660054000000000000
DA Stat : v4.2 on BBID : 0x8B
DRAM not initializewd , configure DRAM Settings
[NAND] : FLASH_VEN : 0x0080 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect failed [1F]! Send report to support!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:02:05
Old 04-29-2015, 05:42   #7 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
6572 emmc
Scatter Load Ok , BaseBand : MT6572 , Project : hexing72_wet_jb3 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.18 ]
======= Flash
Wait for phone...
Phone found! [ 14 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 11010030303447393010940973607031
Error : DA init Failed! Error code : 0x5
Boot Error!
Operation Failed
Elapsed: 00:00:06
Old 04-29-2015, 05:44   #8 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
please add in CM2 MTK v1.18 stop battan com port
Old 04-29-2015, 06:05   #9 (permalink)
Member: 291071
Sonork: 100.1663377
Thanks Meter: 18
plz plz add mtk6571 nand chip falshing full support plzzzzzzzzzzzzzzzz
Old 04-29-2015, 06:17   #10 (permalink)
Member: 1824929
Thanks Meter: 99
also Need remove Gmail option without risk
Old 04-29-2015, 07:30   #11 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Lenovo A1000-T MT6577 read full info and FF done-
Read Info-
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 0300771F
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U5
[eMMC] : FLASH_CID : 1501004B355530304D028069C4C690A3
[eMMC] : FLASH_LEN : 0x00000000E9000000
EXT RAM    : 0x40000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Lenovo
ProdName  : IdeaTab_A1000-T
ProdModel : IdeaTabA1000-T
Device    : A1000T
AndroidVer: 4.1.2
MTKxCPU   : MT6577
MTKxPRJ   : A1000T_A412_01_24_130329_CN
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 0300771F
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Image Ok] : preloader_huaqin17_td_tb_jb.bin
[Image Ok] : dspbl data erased , will skip it
[Image Ok] : MBR
[Image Ok] : EBR1
[Image Ok] : lk.bin
Brand     : Lenovo
Device    : A1000T
AndroidVer: 4.1.2
MTKxCPU   : MT6577
[ScatCFG] : MT6577 / V1.0.0 / huaqin17_td_tb_jb / EMMC
FW Size : 676 MiB
Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6577__Lenovo__IdeaTabA1000-T__A1000T__4.1.2__A1000T_A412_01_24_130329_CN\
All done!
Done!
Elapsed: 00:07:44
Br.
Old 04-29-2015, 07:39   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Post details about modem.
MT6253 supported by old CM.
No plans to add things in CM2 which are already in old CM.
Br.
Old 04-29-2015, 07:49   #13 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Wait for phone...
Phone found! [ 40 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:09
Hello,
Nand not supported for Factory Firmware reading yet, will be supported in coming updates. For now you can read dump.
Wait for phone...
Phone found! [ 14 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:02:05
Hello,
What is the condition of the phone? Don't press any key while connecting the phone. Also you can change settings : Settings -> Other -> NAND init Mode and try again.
Br.
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 14 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:06
Hello,
If phone dead try to Init Preloader from extra tab with matching file.
Hello,
What is necessary will be added one by one.
Br.
Hello,
Will be added in coming updates.
Br.
Hello,
All options will be added one by one, so wait for updates.
Br.
Old 04-29-2015, 07:58   #14 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
Gaba A72 flash read ok
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 7001004D4D4330344758037E020851E5
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344758037E020851E5
[eMMC] : FLASH_LEN : 0x00000000E6800000
SOC VERIFY : C1
Boot Ok!
Brand : gaba
ProdName : ratech72_wet_rlk_jb3
ProdModel : A72
Device : Android
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : G307_E1_GABA_V0.5_20140827
Done!
Elapsed: 00:00:19
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : gaba
ProdModel : A72
Device : Android
AndroidVer: 4.2.2
MTKxCPU : MT6572
[Read Ok] : preloader_ratech72_wet_rlk_jb3.bi
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / ratech72_wet_rlk_jb / EMMC
FW Size : 838 MiB
Scatter saved to : C:\Documents and Settings\sahid\Desktop\MT6572__gaba__A72__Android_ _4.2.2__G307_E1_GABA_V0.5_20140827\
All done!
Done!
Elapsed: 00:04:19
The Following User Says Thank You to srworld For This Useful Post:
Old 04-29-2015, 08:12   #15 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
And again , things, which really need to check :
Page generated in 0.37297 seconds with 8 queries
