02-25-2017, 06:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | when this model (a7020a48) supported...???? Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC Files found : 18 , Set to Flash : 17 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Skip HW_COMPATIBILITY_CHECK by User request! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! Processing : Writing all Flash Files Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001BC0000 Erase : 0x0000000004BC8000-0x0000000004000000 Erase : 0x000000000A000000-0x0000000001000000 Erase : 0x000000000B300000-0x0000000002480000 Erase : 0x000000000DC80000-0x000000033E380000 Flash Erase Done, time used : 00:00:01 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! User selected Preloader file : preloader_k52_a48.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 150100523231424D42 , Name : R21BMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100523331424142 , Name : R31BAB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A484147346132 , Name : HAG4a2 , Vendor : 90 , [HYNIX] FlashID [3] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [4] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [5] CID : 90014A484247346132 , Name : HBG4a2 , Vendor : 90 , [HYNIX] FlashID [6] CID : 150100525831344D42 , Name : RX14MB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 150100523231424D42 , Name : R21BMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100523331424142 , Name : R31BAB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A484147346132 , Name : HAG4a2 , Vendor : 90 , [HYNIX] FlashID [3] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [4] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [5] CID : 90014A484247346132 , Name : HBG4a2 , Vendor : 90 , [HYNIX] FlashID [6] CID : 150100525831344D42 , Name : RX14MB , Vendor : 15 , [SAMSUNG] BL : Storage supported by BootLoader! Sending BootLoader ... Init BL #1 : 0001 Init BL #2 : 0001 PartTable Init Ok , Count : 20 All Done Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! after some try alive with sp flash tool but its ask for image dl error it also not fix by cm2 |
02-25-2017, 08:59 | #3 (permalink) |
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079BA5E0436355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x2CC2286CBF6A1BCBBFE7CEF861D6832F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BM41X , 0x747C00000 , 29820 MiB [eMMC] : CID : 150100525831344D42079BA5E0436355 [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
