10-11-2015, 11:37 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | New Level of DataDirect : FP (625a/6260/6261) Galery extraction :) http://forum.gsmhosting.com/vbb/f296...-test-2000581/ 12 photos extracted for a 12 seconds, including boot time. Code: Operation : Read UserData [ v1.33 ] Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 348475F8D6F276085AFFE27EE93D372C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Processiung : User Photo/Video/Records extraction Read Ok, total read : 231 KiB Data Saved to : C:\InfinityBox\CM2MTK\Read_out\MT6260___348475F8D6F276085AFFE27EE93D372C Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
