03-31-2017, 18:42 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | mtk 6797 repair imei fail Card found : S/N : A6C080ED , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ [eMMC] : FLASH_CID : 150100434A4E423452072979B237830F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xDE96B4FF459971A4B9C827C3700B4D22 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! IMEI [00] : xxxxxxxxxxxxxxxxx IMEI [01] : xxxxxxxxxxxxxxxxx Set IMEI [00] : xxxxxxxxxxxxxxxxx Set IMEI [01] : xxxxxxxxxxxxxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 40 ] Sync... Device boot not done Check Drivers Try again |
The Following 3 Users Say Thank You to hippolyte85 For This Useful Post: |
04-01-2017, 09:21 | #6 (permalink) |
Major Poster Join Date: Jan 2017 Location: Dhaka.BD
Member: 2667438 Status: Offline Sonork: 100.1676500 Thanks Meter: 34 | here the link http://forum.gsmhosting.com/vbb/f723...modem-1636173/ |
The Following User Says Thank You to SaddamHosainSD For This Useful Post: |
