11-26-2016, 13:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | cm2 qlm not detecting phone mtn steppa 2 lte Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! failed but with other box its detecting successfully in edl mode Device : CoreID_007050E1 Core : Qualcomm MSM8916 Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB Connect successful. |
12-30-2016, 09:40 | #3 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
Try use EDL modified Cable | |
12-30-2016, 09:41 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Insyall drivers. | |
12-30-2016, 10:07 | #5 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: South Africa/Pakistan Age: 44
Member: 476940 Status: Offline Thanks Meter: 57 | Quote:
1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 09F7044F ID_BLOCK_I : 007050E1 ID_BLOCK_L : 54ACC6309F0B3033EC41B39C5B26AE9E ID_BLOCK_L : D2A16FBEB3228C19BC7B5C959F16004B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : MTN ProdName : Steppa2 ProdModel : MTN Steppa 2 LTE Device : Steppa2 AndroidVer: 4.4.4 Manufact. : MTN QLMxCPU : MSM8916 QLMxPRJ : TBW572513_9752_V020101_20150304-2358 DevInfo : MSM8916__MTN__MTN__ANDR_v4.4.4__MTN_Steppa_2_LTE__ Steppa2__Steppa2__TBW572513_9752_V020101_20150304-2358 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 857 MiB Done! Elapsed: 00:03:18 | |
The Following 3 Users Say Thank You to nasimshoukat For This Useful Post: |
04-11-2017, 18:51 | #6 (permalink) |
Junior Member Join Date: Jan 2013 Location: south africa
Member: 1865727 Status: Offline Sonork: [email protected] Thanks Meter: 0 | any one have mtn stappe 2 Lte usb drivers |
06-21-2017, 09:23 | #7 (permalink) |
Junior Member Join Date: Oct 2016 Location: Jagdishpur amehti Age: 25
Member: 2638652 Status: Offline Thanks Meter: 1 | How it can connect Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 857 MiB Done! Elapsed: 00:03:18[/QUOTE] |
