NKhan_Gsm | 03-31-2016 11:19 | CM2 Show some MTK SP Locked phone unlocked and can not be unlocked I received a BLU Dash 3.5 II MTK6582 SP Locked but when want to unlock by CM2 in Read Code show false and in Direct Unlock show Not Locked!
here is logs: Quote:
Operation : SP Unlock [ v1.44 ]
Mode : Read Codes
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447326111012CB7B9B8A215
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111012CB7B9B8A215
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 8EC6F84782C9B378D007CEE2C1A29DE4
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Slot[1] SIMLock Info :
[1] Level , [Locked] : False
[2] Level , [Locked] : False
[3] Level , [Locked] : False
[4] Level , [Locked] : False
[5] Level , [Locked] : False
[6] Level , [Locked] : False
[7] Level , [Locked] : False
Slot[2] SIMLock Info :
Done!
Elapsed: 00:00:17
Reconnect Power/Cable!
Mode : Direct Unlock
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Lock Status : Not Locked!
Done!
Elapsed: 00:00:15
| and also I had another same problem with a secure boot Chinese MTK6571 SP locked phone http://forum.gsmhosting.com/vbb/f296.../#post11662839
WBR |
