10-14-2017, 12:33 | #1 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2493870 Status: Offline Thanks Meter: 16 | CM2 SPD module Wait for phone... Phone found! [ 25 ] port opened Sync... initial boot failed boot not don, reason : Wrong bootkeys hint:reset power and use another bootkey (vol up or vol down) i have the SPD driver install`t , CM2SPD v1.27 pleas help |
10-14-2017, 14:37 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Hold correct boot key,, R use Boot JIG to boot,, try vol+,, | |
10-15-2017, 14:32 | #8 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Bro, once u already known type of your phone CPU I don't think it's surpose to hard again... At times one need to select boot in service mode.. Press vol down then connect cable or use miracle boot JIG. Also check ur cable, if u have more than one cable try to use another... Good luck... |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-17-2017, 14:05 | #9 (permalink) | |
Member: 2493870 Status: Offline Thanks Meter: 16 | Quote:
Thanx Yusuf Lawal , the miracle boot JIG work for me , and techno W4 boot normal in spd module Thanx for you guys | |
The Following User Says Thank You to muddather For This Useful Post: |
12-03-2020, 20:10 | #12 (permalink) |
Junior Member Join Date: Nov 2020 Location: pakistan Age: 30
Member: 2973937 Status: Offline Sonork: 100-650600 Thanks Meter: 0 | Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) model q infinity c |
