04-08-2019, 05:05 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | cm2 updates, when are we going to see a big one anytime? thank you. keep up the good work |
The Following User Says Thank You to eivelice For This Useful Post: |
04-08-2019, 06:24 | #4 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
04-08-2019, 21:24 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Please don't spread fake news, it's not fair and it's big sin. Before make new post please read news here - https://www.infinity-box.com/news/ |
04-08-2019, 21:25 | #7 (permalink) |
04-08-2019, 21:26 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
Also I suggest you check news here https://www.infinity-box.com/news/ | |
04-10-2019, 08:16 | #9 (permalink) | |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | Quote:
like a3s password password, frp and also, i am not here to argue. just asking if there is any new updates coming up. because its been a while. that is all. not trying to offend anyone. also, if you can see on the latest news, most of the updates are not cm2, the last update on cm2 SPD is february 20, 2019. the others are for different purposes. thank you and also, i have this problem on some flare s6, maybe this log could help : Code: ========================= Start ========================= 4/8/2019 / 2:56:55 PM ========================================================= Card found : S/N : 45225891 , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : CherryMobile Device Model : t101_cherry Device CPU : MT6589 Device IntName : A650 Device Version : 4.2.2 Device Compile : 11/20/2013 4:10:35 AM Device Project : ALPS.JB2.MP.V1.21 Device ExtInfo : A650 Ready to Flash! Start at : [4/8/2019 / 2:57:27 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4D0001703430434DA20858471BB0BDA3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034475808A2A3BDB01B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x3D746C8386DDD254E7A5A0044777DE7F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! but it cm2 is saying it is not compatible. then i tried another phone, different model, cm2 says the same, hardware is not compatible. i tried uninstalling, installing cm2, still the same outcome. i flashed on other software, it flashed, but with the same scatter, cm2 is saying it is not compatible. Last edited by eivelice; 04-10-2019 at 08:22. | |
04-10-2019, 08:29 | #10 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Uncheck HW Check option and try again. Would recommend to backup firmware, NV and check eMMC state before doing it. Br. Infinity-Box Team. | |
04-10-2019, 20:13 | #11 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
You can check this page from time to time. also, if you are a programmer and want to help to release new software faster - you are always welcome to contact us and talk about cooperation. | |
