-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   cm2 v2.00 r2 error in flashing meizu m1e help (http://forum.gsmhosting.com/vbb/f296/cm2-v2-00-r2-error-flashing-meizu-m1e-help-2393058/)
djjeff 25 04-29-2018 07:06
still can flash my meizu m1e
Operation : Write Flash [ v2.00 r2 ]
Repartition : Enabled
Flash Verify : Enabled
Pre-Erase : Enabled
Verify HW/SW : Enabled
XData Backup : Disabled
Files :19
[FL] : Set : preloader_meizu6755_66_m.bin
[FL] : Set : recovery.img
[FL] : Set : custom.img
[FL] : Set : devinfo.bin
[FL] : Set : md1rom.img
[FL] : Set : md1dsp.img
[FL] : Set : md1arm7.img
[FL] : Set : md3rom.img
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : trustzone.bin
[FL] : Set : secro.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x89C0C7B4 [ 2.15 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM27)
MODE : PRELOADER PORT
PORT : 27
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000007
BROM : SecMode : SBC+SLA+SDA
BROM : PRELOADER PORT
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100525831424D42072639C67AA395
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0008 , EVOL : 0x0000
RNID : 98D0E3B82D47E4E54C85004F936110D
DA : USB : HIGH-SPEED
Boot done!
[FL] : HW verification passed!
[FL] : RePartition
ERR : 0xC0020004
ERR : SEC_DL_FORBIDDEN
ERR : 0x00000000|0x00004400
Error : Flashing failed!
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
Reconnect Power/Cable!
sky73 04-29-2018 08:31
its a bad idea not reading update logs
Known issues/warnings/info :
1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-Write data, which you want, ignore "EMPTY" states.
4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
mbiborna 04-29-2018 08:48
Also protocol version set to 1 & try.
alkim 04-29-2018 08:55
how about build in battery
JayDi 04-29-2018 10:08
That is done automatically, when select MEIZU.
protocol rules can be found in rules.mk at boot files dir.
User can tune up it if need, when make own collection.
Did you hear about forced HW reset? Yes, it made for devices with embded battery.
.:Sanjh Phoenix:. 04-29-2018 12:36
Meizu m91 also not supported, if possible please support
mobilehelper 04-29-2018 12:48
how to solve..............help us.
http://forum.gsmhosting.com/vbb/f296.../#post13106078
Page generated in 0.21896 seconds with 6 queries
