11-13-2019, 00:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: Alexandra ,Johannesburg
Member: 2549090 Status: Offline Sonork: JIJO ALEX Thanks Meter: 11 | CM2MT2 Module Installation issue Please help fix this Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM46) MODE : BOOTROM PORT : 46 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
11-13-2019, 04:35 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
Remove battery, cable. Check cable then Repeat operation! | |
The Following User Says Thank You to sneha For This Useful Post: |
11-13-2019, 23:09 | #4 (permalink) |
Member: 2549090 Status: Offline Sonork: JIJO ALEX Thanks Meter: 11 | I also uninstalled this module 3times and nothing changed. All operations just runs from start to end without letting/waiting for me to connect device |
11-13-2019, 23:22 | #5 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, you have the well-installed mtk drivers, check the cable or change the usb port, the software works perfectly. |
The Following User Says Thank You to Franky_36 For This Useful Post: |
11-14-2019, 04:41 | #6 (permalink) | |
let me understand your problem : you mean you start process in cm2mt2 but set not connected with PC and cm2mt2 show you this error ? can you show device manager when you start process , | |
11-14-2019, 14:09 | #7 (permalink) | |
Member: 2549090 Status: Offline Sonork: JIJO ALEX Thanks Meter: 11 | Quote:
Please understand that this is unusual. I unlocked phones before using mtkmt2 but this new ver2.06 surprise me because it does not wait for a phone to be connected. Once i press any operation it runs past Where i must connect usb/phone to computer. I hope you understand...it does not pause for me to put usb cable to connect phone and computer. | |
11-14-2019, 14:15 | #8 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
I guess u are having a connection problem cuz I have no problem with mtkmt2 version 2.06 and this log is the prove: Code: Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM189) MODE : BOOTROM PORT : 189 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32364E1F7F03424F15529A DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100464E36324D42037F1F9A52154F NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42037F1F9A52154F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 86D180226BBE6807B40D2540A818B479 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM51) MODE : PRELOADER PORT PORT : 51 Boot done! Patch Level : NRD90M Display ID : F2-VP510ABC-N-180304V7 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-02-05 Build Time : 1520149264 Product Model : TECNO F2 Product Brand : TECNO Product Name : VP510 Product Device : TECNO-F2 Product Manfct : TECNO MOBILE LIMITED Board Platform : mt6580 Product Info : sr6580_weg_n USERDATA : ENCRYPTED IMEI[0] : 3549*********** IMEI[1] : 3549*********** IMEI[2] : 354************ NVRAM check : Passed! Done! Elapsed: 00:00:53 b.r. | |
11-14-2019, 14:43 | #9 (permalink) | |
Kindly understand that this happens before i connect a phone...so this has to do with either the installation...there must be something im missing from the installation of this module. | |
11-15-2019, 13:07 | #14 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, There is no connection problem with latest CM2MT2 or any other module. Seems problem is particular with your pc only. Try to look at hidden ports in device manager and uninstall all mtk ports/drivers, restart pc, install driver from support area and try to connect phone with software. Br. Infinity-Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
11-15-2019, 23:29 | #15 (permalink) | |
Tnx to all who adviced up to this far | |
The Following User Says Thank You to MOLETJI For This Useful Post: |
