Old 04-28-2018, 08:27   #1 (permalink)
Member: 2006990
Thanks Meter: 540
CM2MT2 r2
MT6739 support, SPUnlock and more!
- Main
MT6739 CPU supported!
MT6739 moved from TEST to GENERAL support.
Firmwware read
Firmware write
NVRAM read
NVRAM write
Reset Settings / Format FS
Reset FRP
Reset Privacy
MemoryTool
- MemoryTool
Fixed PMT init on some devices
Optimized Expand/Collapse view functions
Fixed DA1804 and DA1712 loaders support for WIPE
Optimized NAND support
- Service
NVRAM module updated
.dynamic page detection
.some types support fixed
.repair security ( security type detection ) updated
FormatFS / Reset settings rebuild
.Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL )
."FULL FACTORY" mode set to default
.Some "OLD" agents (DA15xx) may not work
- SP Unlock activated
Support all MTK modern phones, except MT6763 and MT6739.
Read codes and Direct Unlock mode supported
MT6570 eMMC ONLY devices supported
- Core
Fixed memory leak issues and problems with booting on some systems
Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line )
SW more faster now
EMI handler for MT6570 and MT6797 fully automated and complete
Improved EMI lookup support for MT675x devices
EMIDB updated
Hint/Error explain module updated
MT6758 support under test
MT6771 support under test
- Flasher
Fixed break issue, when just one file selected for flashing.
HWInfo compatibility status shown in log in both cases ( succes or failed )
- FW reader
MT6739 support
New types of firmwares supported
Optimized NAND reading on DA18xx line loaders
Read Firmware size now shown in log
- New models included
Limited MEIZU support
Limited Oppo support
Limited Gionee support
Limited BQ support
Some basic "generic" secure devices support optimized
Known issues/warnings/info :
1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-Write data, which you want, ignore "EMPTY" states.
4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
this is the only upgrade package. unzip to a folder with the installed program
Link CM2MT2_r2.7z ? RGhost ? ?????????????
The Following 3 Users Say Thank You to Surtax For This Useful Post:
Old 04-28-2018, 08:34   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Now will start lot of blaming : it not start after "upgrade"!
@all : For public better wait for complete installer. All cry about sw not start - will be ignored.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 04-28-2018, 09:22   #3 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
GOOD WORK
The Following User Says Thank You to Kirumira For This Useful Post:
Old 04-28-2018, 09:50   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
from support download it say archive corrupted
Old 04-28-2018, 10:10   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Use 7z for extracting and try to redownload setup once again. I have checked just now setup extraction has no problem.
Br.
Infinity Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 04-28-2018, 10:19   #6 (permalink)
Member: 1328371
Thanks Meter: 121
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Infinity Box Team.
no problem extracting now
Old 04-28-2018, 10:19   #7 (permalink)
UzUnlocker's Avatar
Member: 1912005
Sonork: 100.1658592
Thanks Meter: 622
download and install latest 7zip tool.
The Following User Says Thank You to UzUnlocker For This Useful Post:
Old 04-28-2018, 10:32   #8 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
1st setup was 36mb just now i again download and it was 156mb hope its full setup now
Old 04-28-2018, 13:36   #9 (permalink)
Member: 1677653
Thanks Meter: 2,769
Maybe u downloaded wrong exe before
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 04-28-2018, 13:56   #10 (permalink)
Member: 692833
Thanks Meter: 24
why softwer did not open on my dongle????
Old 04-28-2018, 15:25   #11 (permalink)
Member: 1677653
Thanks Meter: 2,769
Run dongle manager v1.72
Click update once wait for operation to completed.
Copy and paste the text here
Page generated in 0.21361 seconds with 8 queries
