== CM2MT2 v2.00 r2 == == CM2MT2 v2.00 r2 == MT6739 support, SPUnlock and more! - Main MT6739 CPU supported! MT6739 moved from TEST to GENERAL support. Firmwware read Firmware write NVRAM read NVRAM write Reset Settings / Format FS Reset FRP Reset Privacy MemoryTool - MemoryTool Fixed PMT init on some devices Optimized Expand/Collapse view functions Fixed DA1804 and DA1712 loaders support for WIPE Optimized NAND support - Service NVRAM module updated .dynamic page detection .some types support fixed .repair security ( security type detection ) updated FormatFS / Reset settings rebuild .Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL ) ."FULL FACTORY" mode set to default .Some "OLD" agents (DA15xx) may not work - SP Unlock activated Support all MTK modern phones, except MT6763 and MT6739. Read codes and Direct Unlock mode supported MT6570 eMMC ONLY devices supported - Core Fixed memory leak issues and problems with booting on some systems Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line ) SW more faster now EMI handler for MT6570 and MT6797 fully automated and complete Improved EMI lookup support for MT675x devices EMIDB updated Hint/Error explain module updated MT6758 support under test MT6771 support under test - Flasher Fixed break issue, when just one file selected for flashing. HWInfo compatibility status shown in log in both cases ( succes or failed ) - FW reader MT6739 support New types of firmwares supported Optimized NAND reading on DA18xx line loaders Read Firmware size now shown in log - New models included Limited MEIZU support Limited Oppo support Limited Gionee support Limited BQ support Some basic "generic" secure devices support optimized Known issues/warnings/info : 1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! == CM2MT2 v2.00 r0 == MTK 6570 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ] Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ] Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6750 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6755 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6757 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6763 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6797 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool --- Under Test --- MTK 6758 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6739 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool Main - New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ] - New core. All code made from scratch. - New boot chain selection mode - automatic ( via defined user combination ) or manual. - New connection - Complete error handling and explanation - Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices - Easy end user customization for adding support for new device etc Flasher - Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ] FW Reader - Completely new core, which allow handle all existing types and flash devices. Service - Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct. - Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection ) - During NVRAM read/write SW also verify it condition and data MEMORY TOOL activated! Easy, fast and ultimate solution now come in MTK too! - Support eMMC and NAND flash IC`secure - Allow READ, WRITE, ERASE partitions - Show partitions states and info only for eMMC devices - Allow RE-init PMT ( from scatter ) Other Lot of other changes from v1 line, which not mandatory to mention Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-write data, which you want, ignore "EMPTY" states. 4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar In some cases WIPE partition may not work! 5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing 6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 7. Device with NV_TYPE2 security may not work yet for repair sec! Index of pub/software/ Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - |
Official information - http://forum.gsmhosting.com/vbb/f296...-more-2393813/ |
