Old 04-28-2018, 12:48   #1 (permalink)
Member: 1695191
Thanks Meter: 24
== CM2MT2 v2.00 r2 ==
MT6739 support, SPUnlock and more!
- Main
MT6739 CPU supported!
MT6739 moved from TEST to GENERAL support.
Firmwware read
Firmware write
NVRAM read
NVRAM write
Reset Settings / Format FS
Reset FRP
Reset Privacy
MemoryTool
- MemoryTool
Fixed PMT init on some devices
Optimized Expand/Collapse view functions
Fixed DA1804 and DA1712 loaders support for WIPE
Optimized NAND support
- Service
NVRAM module updated
.dynamic page detection
.some types support fixed
.repair security ( security type detection ) updated
FormatFS / Reset settings rebuild
.Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL )
."FULL FACTORY" mode set to default
.Some "OLD" agents (DA15xx) may not work
- SP Unlock activated
Support all MTK modern phones, except MT6763 and MT6739.
Read codes and Direct Unlock mode supported
MT6570 eMMC ONLY devices supported
- Core
Fixed memory leak issues and problems with booting on some systems
Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line )
SW more faster now
EMI handler for MT6570 and MT6797 fully automated and complete
Improved EMI lookup support for MT675x devices
EMIDB updated
Hint/Error explain module updated
MT6758 support under test
MT6771 support under test
- Flasher
Fixed break issue, when just one file selected for flashing.
HWInfo compatibility status shown in log in both cases ( succes or failed )
- FW reader
MT6739 support
New types of firmwares supported
Optimized NAND reading on DA18xx line loaders
Read Firmware size now shown in log
- New models included
Limited MEIZU support
Limited Oppo support
Limited Gionee support
Limited BQ support
Some basic "generic" secure devices support optimized
Known issues/warnings/info :
1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
Read-Write data, which you want, ignore "EMPTY" states.
4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
== CM2MT2 v2.00 r0 ==
MTK 6570 CPU support:
with NAND memory
with eMMC memory
Read Info - Complete device info, Security info
Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ]
Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ]
Read NVRAM
Write NVRAM
Repair Security
Formay FS - FRP, Settings, Privacy ( and mixed/special mode )
MemoryTool
MTK 6750 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6755 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6757 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6763 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6797 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
--- Under Test ---
MTK 6758 CPU support:
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
MTK 6739 CPU support:
with NAND memory
with eMMC memory
Read Firmware
Write Firmware
Read NVRAM
Write NVRAM
Repair Security
MemoryTool
Main
- New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ]
- New core. All code made from scratch.
- New boot chain selection mode - automatic ( via defined user combination ) or manual.
- New connection
- Complete error handling and explanation
- Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices
- Easy end user customization for adding support for new device etc
Flasher
- Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ]
FW Reader
- Completely new core, which allow handle all existing types and flash devices.
Service
- Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct.
- Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection )
- During NVRAM read/write SW also verify it condition and data
MEMORY TOOL activated!
Easy, fast and ultimate solution now come in MTK too!
- Support eMMC and NAND flash IC`secure
- Allow READ, WRITE, ERASE partitions
- Show partitions states and info only for eMMC devices
- Allow RE-init PMT ( from scatter )
Other
Lot of other changes from v1 line, which not mandatory to mention
Known issues/warnings/info:
1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices!
Read-write data, which you want, ignore "EMPTY" states.
4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar
In some cases WIPE partition may not work!
5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing
6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
7. Device with NV_TYPE2 security may not work yet for repair sec!
Index of pub/software/
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else -
The Following User Says Thank You to NIMAGA For This Useful Post:
Old 05-01-2018, 23:30   #2 (permalink)
Member: 1043909
Thanks Meter: 51,494
Official information - Chinese Miracle-2 MTK/Mediatek v2.00 r2 - MT6739 support, SPUnlock and more
Page generated in 0.32785 seconds with 7 queries
