12-01-2014, 22:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | CM2MTK v1.07 Pre-release Link : CM2MTKv107 Main things : Universal NAND support for MTK6571/MTK6572 - need make "Read Info" before rest operations. For example - take phone - make read info and do after whatever you want. If want do next phone - make read info and do whatever you want. eMMC phones no affected to that requirements. MTK6575 NAND support fix Security Repair revised for SP phones ( drvier/detection problem ) MTK6573 initial support Simplified Format FS procedure for eMMC phones Added support for format non-aligned PMT phones ( mostly - MT6575 eMMC phones, like - Alcatel, Lenovo and some MT6573 NAND ) Some other fixes and changes. Interest check some not supported before NAND phones and MT6575 operations. Writing and some more things will follow. |
The Following 7 Users Say Thank You to Dzirt For This Useful Post: |
12-02-2014, 02:14 | #2 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | please full support for mt 6575 - 6515 . Card found: S/N xxxxxxxx Chinese Miracle II [MTK module] v 1.07 Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read PatternLock [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Not supported FlashType for this operation Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
12-02-2014, 06:48 | #4 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Pack please, and upload somewhere. Because it must extract full phone info as well. Writing - read my first post. Will be, probably, in next update. Still collect more info. | |
12-02-2014, 07:55 | #5 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | 6575 NAND Read info Code: Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Read flash Code: Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : Andi3.5KKe ProdName : Andi3.5KKe ProdModel : Andi3.5KKe Device : hongyu15_gb2 AndroidVer: 2.3.8 MTKxCPU : MT6575 MTKxPRJ : ALPS.GB2.MP.V2.26 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6575__ANDI3.5KKE__Andi3.5KKe__hongyu15_gb2__ALPS.GB2.MP.V2.26__Android_2.3.8__20130710_064029.ispff Done! Elapsed: 00:04:33 Reconnect Power/Cable! Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Repair Security [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! |
12-02-2014, 08:00 | #6 (permalink) |
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | https://www.fshare.vn/file/TT4BQF3GVT https://www.fshare.vn/file/T1JM4N4DFT pass nhatgiamobile https://mega.co.nz/#!PsIgkbiK!eEcjsY...libF9-u9vV58Zs https://mega.co.nz/#!upJQRCjL!Mfno4q...XiISnZUirOZ4iQ i have many phone for you test Last edited by ngocdiemmobile; 12-02-2014 at 08:09. |
12-02-2014, 09:11 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @ngocdiemmobile , Ok, thanks! Will check them @ishant , In some of next versions will be more repair security methods, so, will be possible choose working way for different cases. By the way - after it start repair security - in phone appear ATE test mode? |
12-02-2014, 10:29 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | MMX-A065 read pattern done- Card found: S/N Chinese Miracle II [MTK module] v 1.07 Start at : [12/2/2014 / 1:52:56 PM] Operation : Read PatternLock [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447581E4EB66B712D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E4EB66B712D [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1173 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 35412 Done! Elapsed: 00:00:47 Reconnect Power/Cable! Br. |
12-02-2014, 10:57 | #10 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Code: @ishant , In some of next versions will be more repair security methods, so, will be possible choose working way for different cases. By the way - after it start repair security - in phone appear ATE test mode? |
12-02-2014, 18:59 | #13 (permalink) | |
Still need more test phones, because all my samples work well with current variant Latest. It not under "Free Test" version. It just internal release before post it in news section and e.t.c. I mostly interested in MT6575 test now, because it had some problems and MT6571/MT6572 new way of NAND support. | |
12-02-2014, 23:50 | #14 (permalink) | |
Major Poster Join Date: Mar 2007 Location: Switzerland
Member: 476333 Status: Offline Sonork: Don't have it !! Thanks Meter: 9 | Quote:
Hello !! You are a Product Supporter ? Can you say me how much credits will cost to activate the Chinese Miracle-2 (Release) MTK/MediaTek v1.06 Update ? Because i have take the Testversion Chinese Miracle-2 (Testversion) MTK/MediaTek v0.03. With this software it detect Huawei Y330 Phone. I have read somewhere that the Huawei Y330 Phone is a MTK CPU based phone. Thanks for your reply. Best regards, Marijo | |
