08-04-2015, 22:09 | #1 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | CM2MTK v1.25 - Forensic Time! MT62xx/MT65xx/MT67xx/MT83xx/MT87xx PhoneBook and MORE! Can test now. Let's call it all "WorldFirst" Main changes : Quote:
OutPut formats (for now) : CSV (Google Format) , TXT ( for printing ) It support Chinese brands and Original phones as well : Alcatel , ZTE , HTC , Meizu , Xiamoi and e.t.c. It is initial version, and not all types can be supported ( mostly it about MTK Feature Phones ) Link : CM2MTKv125 - Download - 4shared | |
The Following 18 Users Say Thank You to JayDi For This Useful Post: |
08-04-2015, 22:11 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6260 , PhoneBook Reading : Code: PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ACEDD9A6226C6647FA60E21DB2996828 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 Step #1 Step #2 Read Ok, PhoneBook records extracted : 7 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6260_PhoneBook.txt Write : 7 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6260_PhoneBook.csv Write : 7 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
08-04-2015, 22:13 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6572, Alcatel 6012 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42013482CC50B0B1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42013482CC50B0B1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 1 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_alc_PhoneBook.txt Write : 1 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_alc_PhoneBook.csv Write : 1 Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
08-04-2015, 22:14 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6575 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D006C6975F89F33 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 22 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6575_PhoneBook.txt Write : 22 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6575_PhoneBook.csv Write : 22 Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
08-04-2015, 22:16 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6582 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2D3BB91E3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2D3BB91E3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 2082 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook.txt Write : 2082 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook.csv Write : 2082 Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
08-04-2015, 22:16 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6592 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040506A11EA48107 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040506A11EA48107 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 1 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6592_PhoneBook.txt Write : 1 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6592_PhoneBook.csv Write : 1 Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
08-04-2015, 22:17 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6572 , Original HTC 210 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010CA918FD331B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393010CA918FD331B7 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 19 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook.txt Write : 19 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook.csv Write : 19 Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
08-04-2015, 22:18 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6589 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D565735C6B5014245B001CC DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201B5C6CC01B045 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 157 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook.txt Write : 157 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook.csv Write : 157 Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
08-04-2015, 22:18 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6752 , Read PhoneBook : Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 6 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6752_PhoneBook.txt Write : 6 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6752_PhoneBook.csv Write : 6 Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
08-04-2015, 23:58 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Link updated : CM2MTKv125 - Download - 4shared |
08-05-2015, 06:11 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Card found: S/N 8F78:0128 Chinese Miracle II [MTK module] v 1.25 Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 66 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42011DD1CA694145 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42011DD1CA694145 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 464 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook.txt Write : 464 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook.csv Write : 464 Done! Elapsed: 00:00:20 Reconnect Power/Cable! thnx genious its great and appricate ur hard work @jayDi |
The Following 2 Users Say Thank You to akhil_bbsr For This Useful Post: |
08-05-2015, 06:22 | #14 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua y2 stuck on logo read phone book wow really great work from team its warm update other box will be INTEX AQUA Y2 STUCK ON LOGO READ PHONE BOOK SUCESSFULLY HERE CONTACT DISPLY ON TEXT Code: 10rath ; 942-423-***** 10rath ; 096-175-***** 2700 ; 080-858-***** AJAY SIR ; 099 81 9***** ASHISH PTH. ; 07049***** Aashish Jija ; 750-987-***** Ainath sahu N.P. ; 090-098-**** Ajay Mandal ; 916-587-***** Ajay Mandal ; 36735******* Ajay Yadav ; 096-304-***** Ajay yadav ; 969-147-***** Ajju ; 084-353-****** Ajju ; +9184353****** Ajju cement ; +91769***** Aman ; 088-715-**** Aman ; +91 96 91***** Amrit tirkey ; 095-755-***** Anad Bhai ; +919926***** Anil Sharma ; 898-266***** Annu ; 072-054-***** Annu ; 081-037-****** Annu Bhabhi ; 088 71***** |
The Following 5 Users Say Thank You to Deepesh Sharma For This Useful Post: |
08-05-2015, 12:03 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Got enough test reports and suggestions in private as well , so, the results satisfy me fully. More stuff will follow. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
