Old 10-11-2015, 08:15   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,708
CM2MTK v1.33 - MTK Smart Anti-Virus , New Level of DataDirect [Pre-release Test]
Hi, seems as some guys can't find link in main thread about it and attack my pm
While monkeys trying delete themself by adb scripts, which they call world-first, we just made real AV
Full changeLog :
Chinese Miracle-2 MTK/Mediatek v1.33 - MTK Smart Anti-Virus , New Level of DataDirect
MTK SP/FP Platform
- New feature supported : Smart AV - World First and Unique!
Allow : Erase all KNOWN and UNKNOWN YET viruses, which can inject their code in Android system (Monkey Tes,Time Service and much others)
NOT Require : ADB , USB Debug, Root , Power on also not required
Result : ALL VIRUSES, THEIR DAEMONS, ACTIVE SERVICES, SHELL SCRIPTS, RECOVERY SCRIPTS will be REMOVED permanently.
Side Effect : For some type of viruses after remove - mobile will not be affected by those one!
Side Effect : Can REMOVE Root or Root Manager (SuperSu) in some cases!
Required after virus remove make "FULL FACTORY RESET". All USER DATA will be DELETED! Backup it before operation!
Emergency requirement : If FW for target phone not available - MAKE FW READ BEFORE and mark it as "INFECTED_MTxxx_...." !
Supported Platforms :
SP : MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6753/MT6795/MT87xx/MT83xx with eMMC
- DataDirect : New feature - Recovery Gallery! - World First and Unique!
Allow DIRECTLY Recover User Photos , Pictures
Allow DIRECTLY Recover User Recordings
Allow DIRECTLY Recover User Video records
Tested with recovery files up to 2 GiB per file!
FP : MT625A,MT6260,MT6261
NOTE : Feature NOT intended to recovery "garbage" content, like music and etc.
About DataDirect feature:
Feature allow recover UserData from damaged/hang/semi-dead MTK Phones and SmartPhones WITHOUT need even power on it!
- Internet connection IS NOT required - all data is private and safe.
- USB Debug/Root etc. IS NOT required - forget about root and rest stuff.
- Alive/working phone/Meta mode etc. IS NOT required
Phone can be completely dead (can not be Powered-On)
If phone can Boot and is not erased - data will be recovered
- Its not required to read our tons dumps and waste 20..200 minutes to read dump
Use any sw to extract something from dump, then ... then .. then ... Just ONE CLICK , 10-40 seconds and you got a result!
- UserData operations improved
PhoneBook Reading improved on SP platform - some older Android versions supported
PhoneBook Reading improved on FP platform - more types supported , autodetection improved
- Firmware reading improved
Brand-specific improvements
Autodetection improved
FP Firmware verification improved , more types supported
Supported Platforms for Factory FW Reading:
MT625A/MT6260/MT6261 with SF/NOR
- Other
FlashID database updated
Some bugfixes and improvements
Much internal changes in different operations
Download: CM2MTK_v133_fx - Download - 4shared
Inside link to EXE only ( EXE ONLY! - mean you MUST change old one with this! )
On link also you can find some Proof-Of and tests reposrts as well.
Version is initial, more features and improvements already on way.
The Following 22 Users Say Thank You to JayDi For This Useful Post:
Old 10-11-2015, 08:26   #2 (permalink)
Member: 307225
Thanks Meter: 45
Hi Sir,
When We Try To Use This Exe For Smart AV EXE Close Itself
Any Help Regarding This Issue ?
Old 10-11-2015, 08:37   #3 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by Abid Hussain View Post
Hi Sir,
It says me nothing. Where is log? Log stored in CM2MTK/Operation.log
Old 10-11-2015, 08:42   #4 (permalink)
Member: 307225
Thanks Meter: 45
Here The Log Sir (Please Check)
Start  at : [10/11/2015 / 11:12:29 AM]
Operation : Check / Read Info [ v1.33 ]
Wait for phone...
Phone found! [ 214 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4838473264040500A2E81A322D
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d2G8
[eMMC] : FLASH_CID : 90014A4838473264040500A2E81A322D
[eMMC] : FLASH_EXT : 00400000/00400000
[eMMC] : FLASH_LEN : 0x00000001D2000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : LINQ
ProdName  : J220_QMobile
ProdModel : LINQ X70
Device    : J220_QMobile
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.10
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Finish at : [10/11/2015 / 11:12:40 AM]
Start  at : [10/11/2015 / 11:12:54 AM]
Operation : Format FileSystem [ v1.33 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:20
Finish at : [10/11/2015 / 11:13:15 AM]
Start  at : [10/11/2015 / 11:13:38 AM]
Operation : Remove Viruses [SmartAV] [ v1.33 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Old 10-11-2015, 08:56   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks for the log. In near 30 minutes will be fixed version.
Old 10-11-2015, 10:01   #6 (permalink)
Member: 1824929
Thanks Meter: 92
give me download link please i have opp0 r831k
Brand : OPPO
ProdName : OPPO72_14079
ProdModel : R831K
Device : OPPO72_14079
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : R831K_11_A.14_150602
virus infected
Old 10-11-2015, 10:07   #7 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 547
Brand : OPPO
ProdModel : R831K
AndroidVer: 4.2.2
MTKxCPU : MT6572
virus infected
wait update on the wey
Old 10-11-2015, 10:26   #8 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 547
An other samsung GT I8552 mt6572 done with cm2
Wait for phone...
Phone found! [ 26 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004E35585A4D4201B2C5D4298125
DA Stat : v4.2 on BBID : 0x88
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D4201B2C5D4298125
[eMMC] : FLASH_EXT : 00400000/00080000
[eMMC] : FLASH_LEN : 0x00000000E9000000
EXT RAM : 0x20000000
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 9
Removing infected files and scripts ...
SmartAV Report : Removed 9 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : PostFix Ok!
Done!
Done!
Elapsed: 00:00:28
Old 10-11-2015, 10:26   #9 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,442
GIONEE V5 Done moneky test
Chinese Miracle II  [MTK module] v 1.33
Wait for phone...
Phone found! [ 60 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004B3758564D420116DAC621416D
[eMMC] : FLASH_INF : BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D420116DAC621416D
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 23
SmartAV Report : Removed 23 infected files!
Done!
Done!
Elapsed: 00:00:48
Wait for phone...
Phone found! [ 60 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:19
The Following User Says Thank You to sneha For This Useful Post:
Old 10-11-2015, 11:30   #10 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 547
samsung g7102 done with sm2
Wait for phone...
Phone found! [ 26 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004B4A5330304D0300E135A611D7
[eMMC] : FLASH_INF : M00SJ
[eMMC] : FLASH_CID : 1501004B4A5330304D0300E135A611D7
[eMMC] : FLASH_EXT : 00100000/00020000
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 27
SmartAV Report : Removed 27 infected files!
Done!
Done!
Elapsed: 00:00:33
Old 10-11-2015, 12:16   #11 (permalink)
Member: 2214243
Thanks Meter: 70
plz upted tool setup 1.33 bro
Old 10-11-2015, 12:18   #12 (permalink)
Member: 580077
Sonork: 100.1591941
Thanks Meter: 146
CM2MTK_v133_EXE_Only.rar' is unavailable.This file was deleted.
The Following User Says Thank You to nori2007 For This Useful Post:
Old 10-11-2015, 12:19   #13 (permalink)
Member: 2214243
Thanks Meter: 70
ok thanks bro kab ayega ne setup bro
Old 10-11-2015, 12:29   #14 (permalink)
JayDi's Avatar
Member: 462970
New link :
Changed algo from "normal" to "deep scan" , now it can take UP TO MINUTE to verify all.
But it kill more viruses as well. Also, chance damage something in system exists.
Anyway - need test , my samples not enough for clear results.
Now it detect in my test samples more viruses and their daemons/sub. Detection ration up on 20-30% from previous version.
Wait for phone...
Phone found! [ 11 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A4838473264040506A11EA48107
DA Stat : v4.2 on BBID : 0x8A
[eMMC] : FLASH_CID : 90014A4838473264040506A11EA48107
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 43
SmartAV Report : Removed 43 infected files!
Done!
Done!
Elapsed: 00:01:26
Wait for phone...
Phone found! [ 11 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:21
The Following 6 Users Say Thank You to JayDi For This Useful Post:
Old 10-11-2015, 12:45   #15 (permalink)
Member: 307225
Thanks Meter: 45
Done One Qmobile A900 With New Fixed Version
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 504E01FE58585830ED5B1058DBB0182B
DA Stat : v3.2 on BBID : 0x86
[eMMC] : FLASH_VEN : 00FE , OEM : 014E
[eMMC] : FLASH_INF : XXXX0
[eMMC] : FLASH_CID : FE014E503058585858105BED2B18B0DB
[eMMC] : FLASH_EXT : 00100000/00100000
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scan Done, infected files found : 31
SmartAV Report : Removed 31 infected files!
Done!
Done!
Elapsed: 00:00:53
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:21
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : QMobile
ProdName  : QMobile
ProdModel : A900
Device    : QMobile
AndroidVer: 4.2.1
MTKxCPU   : MT6589
MTKxPRJ   : ALPS.JB2.MP.V1.2
Done!
Elapsed: 00:00:06
The Following 2 Users Say Thank You to Abid Hussain For This Useful Post:
Page generated in 0.47415 seconds with 7 queries
