Old 12-03-2015, 10:33   #1 (permalink)
Member: 1706168
Sonork: 100.1619095
Thanks Meter: 66
CM2MTK v1.38 can't read pattern lock
It stucks while reading pattern lock , while v1.37 works well
Old 12-03-2015, 12:28   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Would be great to check that issue, if you can make whole flash dump and send me for check. Yes, it big and hard to upload, but without it can't improve that.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-03-2015, 12:30   #3 (permalink)
Member: 1706168
Sonork: 100.1619095
Thanks Meter: 66
Sorry but the customer took the phone , If I could find another phone with such problems, I will
Sent from my iPhone using Tapatalk
Old 12-03-2015, 12:46   #4 (permalink)
JayDi's Avatar
Member: 462970
Yes, that will be great. Will add option in setting for use "old" read mode, if need.
It more universal, but long. Can take up to 5 minutes on 64GiB phones. This one - 20 seconds.
Old 12-03-2015, 19:12   #5 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
My Dear Best Friend,
I'm Also Facing Same Problem.
Operation : Check / Read Info [ v1.38 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 11010030303447453001DB90D0F57115
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0011 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453001DB90D0F57115
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : alps
ProdName  : A60
ProdModel : Karbonn A60
Device    : A60
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : UTLA60v1009_05-12-2014
MODEM :
BaseBand  : MT6572_S00_SM618_GSM4_W1258_MP_V0_0_2_S1020_1_wg_n
EXTRA :
LCD [0] : hx8379c_wvga_ips_auo5p0_618_qy
LCD Res : 0x0
TOUCH [0] : focaltech
CAM [0] : gc2145_yuv
CAM [1] : gc2145mipi_yuv
CAM [2] : ov2685_mipi_yuv
MODEM : SM618_GSM4_W1258
LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG hi_IN ja_JP th_TH kk_KZ pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB fa_IR
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Read Pattern/DP Lock [ v1.38 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Operation : Read PatternLock [ v1.37 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 1599 MiB
Magic Ok
Mount point  : /data
Get PatternLock ...
PatternLock Sequnce : 35789
Done!
Elapsed: 00:00:24
Old 12-04-2015, 01:37   #6 (permalink)
JayDi's Avatar
Member: 462970
Read my previous post, please. If you want and can help - there is explained, what need.
When someone help me with file - it will be fixed at same day.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 06-11-2017, 03:50   #7 (permalink)
Member: 2725936
CM2MTK v1.38 boot eror when i read pattern lock
I want to read pattern lock on my samsung galaxy note 2 n oppo f1s, but everytime i connect the phone, boot eror, can someone help me what to do
Card found : S/N : 740E707F , v0136
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:37
Page generated in 0.15849 seconds with 9 queries
